Diff ratio pop quiz https://www.ausmini.com/forums/viewtopic.php?f=2&t=51699 |
Page 1 of 2 |
Author: | Austin850 [ Tue Mar 31, 2009 8:11 am ] |
Post subject: | Diff ratio pop quiz |
Hi, I've got a moke 140kph speedo (860 turns per kilometre) in my 1293. I checked it against my satnav and it appears to be 100% accurate. Can anybody hazard a guess at to what diff I've got in the car. Cheers, Simon |
Author: | Tombo [ Tue Mar 31, 2009 9:05 am ] |
Open wheeler? |
Author: | ryan [ Tue Mar 31, 2009 9:28 am ] |
what size wheels? |
Author: | poeee [ Tue Mar 31, 2009 9:47 am ] |
What RPM does it sit on at 100km/h? |
Author: | Austin850 [ Tue Mar 31, 2009 9:49 am ] |
Sorry. ![]() 10 inchers with 165/70 Falkens on them. I don't have an operational Tacho at the moment. |
Author: | simon k [ Tue Mar 31, 2009 9:51 am ] |
depends what speedo drive you have in the gearbox... obviously it's the correct one for the diff |
Author: | Austin850 [ Tue Mar 31, 2009 9:57 am ] |
simon k wrote: depends what speedo drive you have in the gearbox... obviously it's the correct one for the diff
Fair enough, Didn't think of that. The gearbox and speedo have come out of two different cars, so I guess that I'm just lucky that they are an accurate combination. I'll try and work it out when I get my tacho working. Thanks. |
Author: | poeee [ Tue Mar 31, 2009 10:00 am ] |
With those tyres I think you should be looking at 3750rpm @ 100km/h with a 3.44 diff. |
Author: | drmini in aust [ Tue Mar 31, 2009 10:02 am ] |
You have a 3.647:1 diff, an 860 turn/km Moke speedo is spot on with this ratio (and 165/70-10 Bridgestones) over the 5km road markers. ![]() I had one in Barney. There is also an 800 turns/km 140KMH Moke one, they are pretty close to correct with a 3.444 diff and 10" wheels. |
Author: | Austin850 [ Tue Mar 31, 2009 10:13 am ] |
I seem to remember that the tacho used to read about 4000RPM at 100 KMH. Mind you the last time I had this engine in a car was 1995! Thanks again guys. |
Author: | poeee [ Tue Mar 31, 2009 10:47 am ] |
4k would be a 3.6. |
Author: | miniDave [ Tue Mar 31, 2009 12:51 pm ] |
drmini in aust wrote: You have a 3.647:1 diff, an 860 turn/km Moke speedo is spot on with this ratio (and 165/70-10 Bridgestones) over the 5km road markers.
![]() I had one in Barney. There is also an 800 turns/km 140KMH Moke one, they are pretty close to correct with a 3.444 diff and 10" wheels. So Doc is the Moke speedo in KMH? My 65 Deluxe has a 90 MPH speedo and I wanted to change to KMH so it should work if I can find a 860 turn/km Moke speedo? (I think I have 3.6 ratio - whatever was in the 65 deluxe - 3 synchro box and 10" tyres) Thanks |
Author: | Blokeinamoke [ Tue Mar 31, 2009 12:53 pm ] |
Is it blue? |
Author: | drmini in aust [ Tue Mar 31, 2009 1:29 pm ] |
miniDave wrote: drmini in aust wrote: You have a 3.647:1 diff, an 860 turn/km Moke speedo is spot on with this ratio (and 165/70-10 Bridgestones) over the 5km road markers. ![]() I had one in Barney. There is also an 800 turns/km 140KMH Moke one, they are pretty close to correct with a 3.444 diff and 10" wheels. So Doc is the Moke speedo in KMH? My 65 Deluxe has a 90 MPH speedo and I wanted to change to KMH so it should work if I can find a 860 turn/km Moke speedo? (I think I have 3.6 ratio - whatever was in the 65 deluxe - 3 synchro box and 10" tyres) Thanks Yes later Mokes were KMH. Bad news for you- the 998 Deluxe was 3.765:1 (same as 850). It's the Mini-K (and 1098 Clubby) that got the 3.647 diff. It won't read correct, but not too far out. |
Author: | Danny [ Tue Mar 31, 2009 1:59 pm ] |
Christ, you reckon they could have made it any more complicated?? Linus' speedo always read a tad high, but I knew that so I was ok. Then the speedo died. Don't know why, haven't had the time to check, and I'm not sure I'd know what to look for anyway. Now I just go by revs, and the rest of the traffic around me ![]() |
