gday all...
havent been on here for some time....been busy with my 7 month old son.
ive been continplating on the idear of making an easter egg shaped like an old style mini.
tried making one from a matchbox pop off mini but turned out not so good.
then i thourght what about a rc mini shell???
well i tried this idear at work and the results were fantastic...
ive so far made one easter egg...witch is about 2 cm thick al round....
and i also made a ice cream cake using the same princapal but instead of just
normal chocolate i used iced majic....
step buy step instructions are as follows.
for easter egg.
melt chocolate....i used coles cheapy brand ...x 5 blocks
melt one block at a time
first block is used to cover the front windscreen ....the roof and the rear window.
you kinda have to rock the shell to cover as much area as possible.
then set in fridge.
repeat same method and do sides...i sat the shell on a plate as it gets messy.
the when it comes to the grill and rear of the car you kinda have to sit the shell on a tilt so the chocolate will stay in that area.
for the chocolate version i used iced majic.....follow same method for easter egg and set...once set i poured 5 1/2 ltr of chocolate ice cream into shell and let set for 3 hours....once set i turned it out on flat tray...please not it may stick a little so tap lightly......
the iced majic seems to grab more than the standard chocolate.
both items ive made and have turned out excelent...
my boy will be getting a chocy egg version for easter for sure .
my shell cost me $30 from my local hobby shop....but if you not into minis.....you could do it to any rc shell thta your into....i was lucky as my shell wasnt original timiah rc....but a replicia...and even better it diddnt have the holes in the bonet or roof but if you get one that does you will just have to cover them up with tape...
hope this kinda makes sense....if i do another one witch il do soon i might do a step by step with photos for all the non cooks out there.....thats if ur interested???
