Thermostat for Mini - 65 https://www.ausmini.com/forums/viewtopic.php?f=2&t=51718 |
Author: | jabba [ Tue Mar 31, 2009 8:12 pm ] |
Post subject: | Thermostat for Mini - 65 |
Hello Guys, Mini is running hot, i think cooling system needs a good flush and a new thermostat, will this one do the job? http://www.minisport.com.au/prod131.htm Can you get these form Repco or are they specific to the mini? Thanks JB |
Author: | sgc [ Tue Mar 31, 2009 8:17 pm ] |
Post subject: | Re: Thermostat for Mini - 65 |
jabba wrote: will this one do the job?
http://www.minisport.com.au/prod131.htm Can you get these form Repco or are they specific to the mini? Thanks JB Yep, that'll do but if your engine is running hot then it's probably not the thermostat. Give it a good flush, clean the radiator and then think about changing the thermostat. Repco et al probably won't have a Mini thermostat in stock, but they'll order one. |
Author: | Morris 1100 [ Tue Mar 31, 2009 8:21 pm ] |
They are not Mini specific, it is a matter of the right size and the right temp. A Chev V8 uses the same thermostat as a Mini and so do a lot of other cars. ![]() |
Author: | jabba [ Tue Mar 31, 2009 8:27 pm ] |
Ok, thanks... Car has been sitting for a while so it could be just a matter of a clean but i would like to be safe as my worst fear is car over heating... After clean i think a new rad cap and thermostat are in order |
Author: | minidrifter [ Tue Mar 31, 2009 8:51 pm ] |
Supercheap stock the mini thermo's on shelf, look for the 1-180 thermo. ![]() |
