What's the trick? - Done but bigger problems
https://www.ausmini.com/forums/viewtopic.php?f=2&t=51744
Page 1 of 2
Author:  Wombat [ Wed Apr 01, 2009 6:08 pm ]
Post subject:  What's the trick? - Done but bigger problems
How do you get the distributor drive back in the block and engaged with the cam?
With #1 at TDC the skirt of #3 is in the way so how do you line it up with the crank rotated enough to get a clear line of sight - and then how do you do it?
Getting frustrated here :x
Author:  drmini in aust [ Wed Apr 01, 2009 6:12 pm ]
turn the motor either way about 10° from TDC. :wink:
Author:  norton [ Wed Apr 01, 2009 6:22 pm ]
make sure you have a long bolt screwed in to it
Author:  Wombat [ Wed Apr 01, 2009 6:39 pm ]
I'm doing both - but don't seem to be able to get the thing to lock in and engage the cam - which way does the turn in relation to the crank - do they both turn anti-clockwise?
Author:  grey 64 [ Wed Apr 01, 2009 6:49 pm ]
Are you holding ya tongue right?
Author:  drmini in aust [ Wed Apr 01, 2009 6:52 pm ]
It will turn clockwise as it goes in. :wink:
Author:  TheMiniMan [ Wed Apr 01, 2009 8:21 pm ]
Wombat,,, hold your tongue slightly to the left & fit it with your eyes closed... feel it slide in nice & gently,,, you know ,,, just the same way you fit your,, er ,,,ar,,,um ,,, OH!!! sorry that won`t be allowed to be said on this forum hey? :-)
Author:  Wombat [ Wed Apr 01, 2009 8:27 pm ]
Got it in - went right in and the outer retainer slipped right in fully. Before I removed the bolt I thought I'd give it a turn to see if it rotated
The (*&$%^ # 3 piston hits the drive shaft and won't go any further :evil:
Guess I'll be giving Mr GR a call in the morning
Author:  drmini in aust [ Wed Apr 01, 2009 8:38 pm ]
With those pistons you have to machine the body of the dizzy driveshaft down to 8mm or so. :wink:
Aaron found the same prob today.
Pic of modded shaft in Vizard's book.
Easy job.
Author:  Wombat [ Wed Apr 01, 2009 8:46 pm ]
Hmmm he's talking stroked engines to clear the crank - this is the skirt of the piston hitting it will it still help?
If so it will be in the mail to you tomorrow :wink:
Author:  drmini in aust [ Wed Apr 01, 2009 8:47 pm ]
Yes it's the same problem. Skirt of RE piston is maybe longer than a normal 1100 one, it's also .100" bigger diameter..
Author:  sitnlo62 [ Wed Apr 01, 2009 8:53 pm ]
Easy job.
Yes, it is an easy job but I wouldn't want to try it with an old Myford and a piece of high speed steel! Those shafts are HARD!
Dave
Author:  simon k [ Wed Apr 01, 2009 8:56 pm ]
jeez, aren't you glad you found that now and not when you hit the starter!
Author:  drmini in aust [ Wed Apr 01, 2009 8:57 pm ]
Easy job.
Dave
You may find it hard to believe but I did just that, in my Myford. 8)
But I'm used to this, I reface Mini valves the same way.
Author:  sitnlo62 [ Wed Apr 01, 2009 9:07 pm ]
Did you think it was hard material?
Maybe the one I did was an exception it was as hard as hell!
Dave
