Bonnet Rattle https://www.ausmini.com/forums/viewtopic.php?f=2&t=51747 |
Page 1 of 2 |
Author: | FOO_SAYS [ Wed Apr 01, 2009 8:14 pm ] |
Post subject: | Bonnet Rattle |
at certain revs im getting a consistant rattle between the bonnet and the body just under front window here.... ![]() any ideas of how to reduce or stop this? i was thinking of putting (jamming) a sliver of rubber in there, but this may not be easy if the bonnet is opened and closed |
Author: | grey 64 [ Wed Apr 01, 2009 8:21 pm ] |
you could throw some sticky backed foam in the channels |
Author: | FOO_SAYS [ Wed Apr 01, 2009 8:22 pm ] |
ah good thinking! is that in anyway water proof? or will it need replacing every so often? |
Author: | Morris 1100 [ Wed Apr 01, 2009 8:23 pm ] |
There should be a rubber strip in there. It sits on the lip of the gutter. If you stick a bit of sponge in the channel it will attract moisture and start to rust. |
Author: | goodie [ Wed Apr 01, 2009 8:26 pm ] |
A mate of mine with a roundie put 2 short pieces ( 2'' ) of pinchweld ,i think they call it ,( it;s the same stuff that goes around the doors less the rubber) ,on the lip at the top or backside of the bonnet, could be worth a try. |
Author: | FOO_SAYS [ Wed Apr 01, 2009 8:27 pm ] |
also a very good point i think ill try my local hardware shop for some sticky rubber there is nothing in the gutter or on the lip so im assuming thats why im getting that rattle |
Author: | Morris 1100 [ Wed Apr 01, 2009 8:28 pm ] |
The proper bit was called "Channel- Bonnet drain" Part number HYB3743. It was like a bit of pinchweld with a lip pointing up. |
Author: | Morris 1100 [ Wed Apr 01, 2009 8:52 pm ] |
I think that this is what it looks like from the side... ![]() |
Author: | drmini in aust [ Wed Apr 01, 2009 8:55 pm ] |
The roundies had a bit of sponge (8x13?) in the channel. Even my 3/70 car has it. That moulded one in the pic is a Clubby thing... ![]() |
Author: | david rosenthal [ Wed Apr 01, 2009 11:16 pm ] |
Try a lump of wood and a big ratchet strap over it ![]() ![]() seriously a strip of "U" shaped rubber woks well. I have heaps of rubber similar to the style that Morris 1100 showed but does not have the little lip. Pm and I will give you some |
Author: | moustache [ Thu Apr 02, 2009 9:15 am ] |
my bonnet pops open pretty much every time i take the car out and rattles when i'm idling at certain revs. anyone know how to go about fixing that? |
Author: | Fiji [ Thu Apr 02, 2009 9:26 am ] |
bonnet strap ![]() maybe try tinkering with the ( don't know what its called bit in the middle front of the bonnet that goes into hole) has to have sonething to do with that |
Author: | FOO_SAYS [ Thu Apr 02, 2009 11:37 am ] |
Fiji wrote: bit in the middle front of the bonnet that goes into hole
couldnt have put it better than myself |
Author: | Wombat [ Thu Apr 02, 2009 11:37 am ] |
moustache wrote: my bonnet pops open pretty much every time i take the car out and rattles when i'm idling at certain revs.
anyone know how to go about fixing that? Araldite a brick to the bonnet then put a fibre glass scoop over the top of it ![]() |
Author: | Fiji [ Thu Apr 02, 2009 11:44 am ] |
LOL thats funny as, more downforce too.... me likes to corner fast. ![]() |
