Mini or Morris 1100 floor mat? https://www.ausmini.com/forums/viewtopic.php?f=2&t=51748 |
Page 1 of 2 |
Author: | sitnlo62 [ Wed Apr 01, 2009 8:22 pm ] |
Post subject: | Mini or Morris 1100 floor mat? |
Hi Guys, does this look like a Mini 850 floor Mat or Morris 1100 Mat? Dave ![]() |
Author: | sports850 [ Wed Apr 01, 2009 8:24 pm ] |
I vote 850 , morris 1100 looked bigger and were ribbed from memory . |
Author: | Morris 1100 [ Wed Apr 01, 2009 8:25 pm ] |
It is not Morris 1100 no matter what he claims on ebay. |
Author: | sitnlo62 [ Wed Apr 01, 2009 8:27 pm ] |
New old stock Mini 850 then? Dave |
Author: | sports850 [ Wed Apr 01, 2009 8:31 pm ] |
Get him to show more photo's if you can , it's missing the floor starter hole and the light dipper switch hole . Don't think the 850 had the embossed heel area either but could be wrong . It does look similar to the mats I got from the Mini King that were from a left hand drive UK mini 850 of some form , it has a super short pile carpet on the top when it's in a left hand drive car but a reasonably original looking rubber backing with the holes mostly in the right place when it's fitted upside down to a right hand drive mini . It didn't have the floor start button or the dipper switch hole either .... |
Author: | sitnlo62 [ Wed Apr 01, 2009 8:41 pm ] |
Here's a photo of an original floor mat in an 850, shows the embossed heal pad, Yes? Dave ![]() |
Author: | sports850 [ Wed Apr 01, 2009 8:55 pm ] |
Yep , I'll agree with that . My front mat was reduced to half a dozen bits and the drivers foot area was a missing piece so wasn't sure . Seen one without that I thought could have been a repro but couldn't prove it one way or another . |
Author: | sitnlo62 [ Wed Apr 01, 2009 9:16 pm ] |
Thanks for your input Ian, I guess I will see when it gets here, For the money I thought it was worth the risk, He did say it was 40 year old new old stock, but on the other hand said it was from a morris 1100 so we'll see! Either way it won't break the bank ![]() Dave |
Author: | sports850 [ Wed Apr 01, 2009 9:17 pm ] |
Good to hear , can you please put some photo's up in here when you get it ? |
Author: | Morris 1100 [ Wed Apr 01, 2009 9:21 pm ] |
sitnlo62 wrote: Thanks for your input Ian,
I guess I will see when it gets here, For the money I thought it was worth the risk, He did say it was 40 year old new old stock, but on the other hand said it was from a morris 1100 so we'll see! Either way it won't break the bank ![]() Dave It can't be for a Morris 1100 for two good reasons... Reason 1) If it was for a Morris 1100 I would have outbid you. Reason 2) The gearstick hole is in the wrong spot. He said that the 1100 auto had the hole in a different spot to the manual but he is wrong. It is in the same spot and the cable runs under the floor. |
Author: | sitnlo62 [ Wed Apr 01, 2009 9:25 pm ] |
Thanks for your input too Morris100, Lets hope it is a mini one. If I thought it was for 1100 I would have not bid so you would have had it for the $80.... Dave |
Author: | sitnlo62 [ Wed Apr 01, 2009 9:41 pm ] |
sports850 wrote: Good to hear , can you please put some photo's up in here when you get it ?
Sure thing Ian, not a problem. Dave |
Author: | Wombat [ Wed Apr 01, 2009 10:08 pm ] |
It's for an 850 cause it's got a bump for the push button floor start |
Author: | Gadgets mini [ Thu Apr 02, 2009 8:19 am ] |
My Morris 1100 floor mat looks different it also whines alot when i rub my feet on it, it also takes off to the pub every now and then ![]() ![]() ![]() |
Author: | drmini in aust [ Thu Apr 02, 2009 8:25 am ] |
It could be for a Mini autoMatic, they used the 850 shifter hole for the cable, and no floor starter. Wombat, all Oz (& UK Mk1 & II) Minis have the starter bump in the floor... |
