Is this a Alternator or Generator?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=51768
Page 1 of 2
Author:  Brad's 68 [ Thu Apr 02, 2009 1:25 pm ]
Post subject:  Is this a Alternator or Generator?
Hi,
My ignition light has been constantly on while driving and the battery finally run out of charge, I assume that the alternator has gone, but while looking at the parts I’m not sure if it is and Alternator or Generator?
Which one do I need?
[/img]
Author:  Tombo [ Thu Apr 02, 2009 1:27 pm ]
Jenny
Could be a voltage reg problem.
Author:  Matt68 [ Thu Apr 02, 2009 1:27 pm ]
That is a generator
Now is the perfect time to think about upgrading to an alternator!
M
Author:  sports850 [ Thu Apr 02, 2009 1:27 pm ]
That's a generator , your battery will most likely be wired in with positive earth (unless the voltage regulator has had it's polarity changed ) so will need some modifications if you intend to fit an alternator . Personal preference and the amount of accesories will decide what you do , big stereo would be better with an alternator but I like generators in my mini's for looks and simplicity .
Author:  ryan [ Thu Apr 02, 2009 1:29 pm ]
That, as above is a Generator. You may just need to get it reconditioned.
Is your car neg- or pos+ earth?
Ryan
Author:  Brad's 68 [ Thu Apr 02, 2009 1:33 pm ]
How can i tell if its Neg- or +pos earth?
Author:  sports850 [ Thu Apr 02, 2009 1:34 pm ]
Look at the battery , which terminal (will be marked with a + or - on the battery) goes to the short cable attached to the body and which one goes to the long cable that runs through the floor and up to the engine bay ?
Author:  Brad's 68 [ Thu Apr 02, 2009 1:57 pm ]
Its Neg - Earth, will an alternator bolt straight in? Or best to stay with the generator?
Author:  drmini in aust [ Thu Apr 02, 2009 2:18 pm ]
Alternator will bolt in if you change the rear bracket.
You will need to do some rewiring around the old voltage regulator area.
A modern alternator has a regulator inbuilt.
Nothing wrong with generators though, usually it's just worn brushes, or dirty points in the regulator.
Author:  Brad's 68 [ Thu Apr 02, 2009 2:31 pm ]
Thanks, I'll have ago at putting in an alternator on the weekend, as i'm looking to fit a stereo soon too.
Brad
Author:  Leighton [ Thu Apr 02, 2009 8:59 pm ]
if your intending to put a stereo in make sure you get a 65 amp alternator.
as the originals were only designed for a radio with 1 speaker and not much else. the 65 amp will leave room for halogen lights, eletronic dizzy etc.
Convertible Mini on here sells them.
Author:  roleyfoley [ Fri Apr 03, 2009 10:18 am ]
you will need to change the regulator around a bit
This link has the instructions on what you have to rewire
http://www.minimania.com/web/SCatagory/ELECTRICAL/DisplayType/Technical%20Information/DisplayID/28/ArticleV.cfm
Author:  Thor56 [ Sun May 24, 2009 6:41 pm ]
sorry to reopen an old thread but sports is there any way of knowing if the polarity has been changed and is/was this a common thing to do (change the polarity of the regulator)
Dane
Author:  aaron [ Sun May 24, 2009 6:46 pm ]
look at the battery, what is connected to the body. that will tell you what polarity it is.
Author:  drmini in aust [ Sun May 24, 2009 7:00 pm ]
as the originals were only designed for a radio with 1 speaker and not much else. the 65 amp will leave room for halogen lights, electronic dizzy etc.
Even a standard Clubby 16ACR alternator puts out 34A, this is 12A more than that generator ever did.
I have halogens, electronic dizzy, stereo, etc. No problemo with stock 16ACR alternator.
I reckon a decent size battery (500CCA+) is more important than a BIG alternator, unless your stereo consumes KW- in which case you want both. :lol:
