Quick change gear stick.. are they any good. would you? https://www.ausmini.com/forums/viewtopic.php?f=2&t=51810 |
Page 1 of 3 |
Author: | NG [ Fri Apr 03, 2009 6:47 pm ] |
Post subject: | Quick change gear stick.. are they any good. would you? |
http://www.minispares.com/Product.aspx? ... T%20GENU... should i get it! i've never ever driven with one. is it a pain? will i hate? it if it's going to be my daily driver. is there much of a difference between this & a normal gear stick? im going to buy up haha ![]() |
Author: | Austin850 [ Fri Apr 03, 2009 7:01 pm ] |
I've got one on my rod change. I bought it about 10 years ago and only just got a car on the road a few weeks ago. It totally transforms a rod change, much less sloppy. You just have to careful not to change too fast as it's still the same gearbox in the end. The only issue with mine is that sometimes when you lift the lever to go into reverse, the slot in the bottom ball pops off the locating pins and you're left with a gearstick that can move in any direction. Not too big a deal as you are generally sitting still at the time ![]() I don't know how the new design compares to the old one. |
Author: | NG [ Fri Apr 03, 2009 7:10 pm ] |
im sure it is but my rover 1994 engine would be a ROD change right? to rods either side of the gear linkage lol |
Author: | Austin850 [ Fri Apr 03, 2009 7:14 pm ] |
If you haven't got a great big housing running from the diff casing back to the gearstick then you've got a rod change. |
Author: | sgc [ Fri Apr 03, 2009 7:17 pm ] |
I don't have the KAD one, but I have the much cheaper Mini Spares version on my daily drive (rod change). Love it, love it, love it. Virtually no slop (but my standard rod-change was pretty precise to begin with) and there's no issue with reverse either. As mentioned though, it's still a Mini gearbox so you can beat the synchro's if you're too heavy handed with it. |
Author: | NG [ Fri Apr 03, 2009 7:20 pm ] |
the one with the big case that sits over the older style engines a remote right? i cant find a picture to show you. the rod jsut hangs under the car with no case to cover it? |
Author: | Austin850 [ Fri Apr 03, 2009 7:21 pm ] |
Yep, that one looks almost exactly the same as mine. I think that other companies copied the original KAD design so KAD redesigned theirs a bit to make it more marketable. I've got the old one |
Author: | Austin850 [ Fri Apr 03, 2009 7:22 pm ] |
NG wrote: the one with the big case that sits over the older style engines a remote right?
i cant find a picture to show you. the rod jsut hangs under the car with no case to cover it? Yes, it sounds like you have a rod change |
Author: | NG [ Fri Apr 03, 2009 7:22 pm ] |
yep it deff is. cheers mate. |
Author: | Dylans Clubby [ Fri Apr 03, 2009 7:33 pm ] |
quick changes are weird at the start, but after you are used to them a regular just feels sloppy. i have heard stories about ones that were crap to fit and use, so make sure its a decent one ![]() |
Author: | Hanra [ Fri Apr 03, 2009 7:51 pm ] |
I bought a KAD one 12 years ago. I couldnt imagine not having one... |
Author: | Fiji [ Fri Apr 03, 2009 9:07 pm ] |
im confused by this all. ( i understand it being a quick shift and shift more quickly). but all these terms got me stumped. remote / rodchange . any one just got a pic of what they fitted it too. sounds interesting ![]() my gearsticks near my left knee, straight down .... can i get one ![]() how difficult is one to fit ? |
Author: | sgc [ Fri Apr 03, 2009 9:14 pm ] |
Fiji wrote: all these terms got me stumped. remote / rodchange
It's pretty straightforward really. There are 3 types of gearchange fitted to Oz Mini's, in order of age: * Magic wand / pudding stirrer * Remote * Rod change Magic wand is irrelevent to this discussion, as you can't fit a quick shift to one of these. With this gearshift, the gear stick comes out of the floor next to the clutch pedal and headlight dipper switch, and is about 3 miles long. Remote and rod change both come out of the floor in front of the hand brake and within the car look pretty much identical. The difference is that the remote change has a large alloy housing which extends from the diff/gearbox right back to the gear shift, which encloses a single rod which is what you move to change gear. With a rod change, the gear stick goes into a box which is bolted underneath the floor, then two rods are attached between it and the gearbox/diff (hence the name). Poke your head under the car and it'll be immediately obvious which you've got. You can fit a quick shift to either rod change or remote gearboxes, but you need to get the right one as the gear sticks and the way they attach are different. |
Author: | 850man [ Fri Apr 03, 2009 9:29 pm ] |
Quickshifts are a good way to wear out balk rings really quick. Mini gearboxs, any gearboxs really shouldnt be slammed through the gears as it just wears them out quicker and goesnt really make you go any faster. A mini gearbox will be buggered in a week if you drive them like a modern car, the syncromesh is'nt up to the job. I have rebuilt many gearboxs after people have fitted quickshift kits (you can make your own using the std gearleaver) and my suggestion would be to leave it standard. You will notice that none of the "quick" mini race cars have them fitted, leave the quickshift kits to the riceburner driving P platers. |
Author: | Fiji [ Fri Apr 03, 2009 10:38 pm ] |
mmmm piont taken. i like the sound of mine being and lasting for a while.. i still need it as my daily and as when shes ready for any rebuilt i want to do the lot. just stick ing to the cruizing now. matt |
Page 1 of 3 | All times are UTC + 10 hours |
