It is currently Tue Jul 22, 2025 5:51 pm
PostPosted: Fri Apr 03, 2009 2:14 pm
Basically I tried searching on this forum but get 27,000 results back. I was wondering if there is a realiable source of information on features and specifications that mini's came with when they left the showroom floor.
I am particularly interested in clubman info from 71-78.
Cheers.
Roundies Rule !!!
PostPosted: Fri Apr 03, 2009 3:15 pm
I don't know of any lists in particular. However mini experience have covered most models (a lot of models). Otherwise, people on here will most likely be able to help.
Ryan
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
PostPosted: Fri Apr 03, 2009 4:04 pm
Ok, the Leyland Mini 1275 LS, did they come with twin tanks as standard like Cooper S?
Whats the difference between GT LS and 1275 LS.
Roundies Rule !!!
PostPosted: Fri Apr 03, 2009 4:15 pm
GT = Cooper S in clubby form, twin tanks, disc brakes, 1275 twin SUs, remote shift, Tacho, early 70s
998 LS = 1977ish, contessa mags, drum brakes, radio, velour seats twin horns spotlights, 998 single SU, rod shift
1275 LS = 1978 long range petrol tank, 8.4" disc brakes, 12" steel wheels with hubcaps, 1275, single SU, radio, velour seats twin horns spotlights, rod shift
A summary anyway :wink:
PostPosted: Fri Apr 03, 2009 4:18 pm
No, never twin tanks, but they had a larger 35 litre fuel tank. This more or less became the standard mini fuel tank from then on for british production.
PostPosted: Fri Apr 03, 2009 4:39 pm
DRB33N,,, no such thing as a "GT LS" made here
PostPosted: Fri Apr 03, 2009 5:05 pm
Thanks for clarifying that.
Roundies Rule !!!
PostPosted: Fri Apr 03, 2009 8:18 pm
watto did a write up on 1275LS models - pm him and get him to send you a copy on CD
PostPosted: Sat Apr 04, 2009 1:15 am
i think he meant
DRB33N wrote:
Whats the difference between GT, LS and 1275 LS.
PostPosted: Sat Apr 04, 2009 6:42 am
GT was about 75HP, LS about 40, 1275LS was 61?.
So the GT had some balls, the others didn't.:mrgreen:
PostPosted: Sat Apr 04, 2009 9:43 am
if u want I'm away, but I have brochures on them, Would u like to to fax u some copies?? (I dont have a scanner) :cry:
PostPosted: Sat Apr 04, 2009 10:44 am
I can help with the scans of brochures if you need them ? Didn't think of that when you first asked actually :oops:
PostPosted: Sat Apr 04, 2009 1:51 pm
It would be great if you can scan them to a PDF file and have them available for download or email them to people who want them. When you get round to it I would like a copy, my email is [email protected]
Roundies Rule !!!
