Is that noise normal?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=51829
Author:  Harley [ Sat Apr 04, 2009 3:30 pm ]
Post subject:  Is that noise normal?
When I drive the mini around, commonly in third or fourth gear and I tap the accelerator on/off quickly there is a noticable thud sound.
I thought the engine stabilisers were worn, so fitted new ones, and I even put in a third stabiliser altogether.
The noise still exists but isnt as loud. Do all minis do this or have I missed something else?
Author:  1310/71 [ Sat Apr 04, 2009 5:00 pm ]
Is it a 1275?
It could be the harmonic balancer rubber worn if it is a 1275. That can also give you an audible knock on idle.
Author:  EST-071 [ Sat Apr 04, 2009 6:20 pm ]
Also if it is a Rover check the sub-frame mounts.
Cheers Pete
Author:  Harley [ Sat Apr 04, 2009 9:45 pm ]
Engine is an 1100 unit. Haven't checked the subframe mounts, will do tomorrow.
:D
