Has anyone got these 12*6 wheels?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=52038
Page 1 of 3
Author:  Lindsay_Palmer [ Sat Apr 11, 2009 10:23 am ]
Post subject:  Has anyone got these 12*6 wheels?
I have been looking at wheel options for my project car and like these:
http://www.minispares-online.co.uk/?cat_id=1&sub_cat_id=15&prod_id=1989
Has anyone got a set/ know someone with a set? What flairs cover them? Do I have to cut the guards? The item description mentions body modifications needed but does not say what they are.
Can't wait to be finished at the end of june so I can get stuck back into the project. I've decided not to buy another alfa and instead put the money into the cars I already have and save the rest.
Author:  EST-071 [ Sat Apr 11, 2009 10:33 am ]
These are 12x6's on steve1965's Clubby.
steve1965 wrote:
NoMoreMinis wrote:
So what are those flares you decided on????
And how much were they?
I'm not sure what type they are or brand, they are made out of fibreglass and are 3" wide.Steve
Cheers Pete
Author:  Lindsay_Palmer [ Sat Apr 11, 2009 10:48 am ]
Thanks for the information and pics
Author:  woodwormm [ Sat Apr 11, 2009 1:46 pm ]
i've got 12x6 Watanabe's (japanese minilight copy), though not on the car in my avatar.
they fit under steel cooper s flares with regular brake, my metro brakes push the rubber out of the flares by 10-15mm.
mine scrub like buggery on the internal flare that holds the external flare on. Can barely get in my drive or around a round-a-bout without carving my tyres..... so i need to do something about it.
i reckon with cut guards and bolt on flares they'd be fine
i'll try and post some pics soonish, but that'll only be rear as my fronts have got steelies on at the moment and in the middle of moving house, so not much time.
cheers.
Author:  dannzhu [ Sun Apr 12, 2009 12:17 pm ]
cheers.
Hi woodwormm,
I have the Watanabe wheels as well, in the process of getting cleaned up and painted. I'm interested to see how bad it scrubbed on the guard.
I guess no way of getting away from cutting the guard huh?
Daniel
Author:  sports850 [ Sun Apr 12, 2009 12:23 pm ]
How about the other factors , how low is your mini , what profile are your tyres etc . If the mini's been lowered then raising the suspension back to standard may reduce the scrubbing . Check everything else out before cutting the guards if you can .
Author:  Lindsay_Palmer [ Sun Apr 12, 2009 6:09 pm ]
The car is still a bare shell so details like ride height, tires, ect have not been worked out. What I really want to know is if anyone has these or similar wheels did they have to cut the guards? I'd rather buy different wheels than cut the guards.
Author:  NG [ Sun Apr 12, 2009 9:37 pm ]
yeh these rims are hot.
id also like a set.
if you do cut your guard will you need to respray anything even if you have the wood & picket flares they sit pretty side.
Author:  Lindsay_Palmer [ Sun Apr 12, 2009 10:36 pm ]
I was looking at group 2 or 5 arches, whichever will cover the wheels and retain the chrome moulding down the side of the car. I am going for a 60s Austin cooper s look but with a few secrets under the skin.
Author:  DTrain [ Tue Apr 14, 2009 10:57 pm ]
well ive been doing some research & you can roll your guards.
no cutting no re spraying the paint does not crack as they use heat to bend it slowly.
http://www.guardrolling.com.au/
they are all over costs about 90 to 150 for 2 guards.
them guard rolling places are for more modern cars where the lip of the panel is on the inside of the arch. they roll it up into the inside of the arch out of the way of the tyre. with a mini the lip is on the outside of the arch and cant be done. cutting would be the only option.
Author:  Lindsay_Palmer [ Wed Apr 15, 2009 10:47 am ]
I just got a email reply from huddersfield spares:
Thanks for your email.
You need to cut out the front wing, from the bumper line to about half
way up. This is for the wheel clearance. Nothing needs to be done on
the rear. The best arches to go with these wheels would be the GP4
arches, which cover the wheels nicely.
Best Regards
Huddersfield Spares Ltd
I have just sent them a email asking if I can fit the chrome side trim with the group 4 flares and if I need to fit a metal supporting lip to the wheel arch for the arch to sit on, but I think regardless I will take the plunge in the next two weeks and order the wheels and flares.
Group 4 flare link:
http://www.minispares-online.co.uk/?cat_id=7&sub_cat_id=55&prod_id=2177
Author:  NG [ Wed Apr 15, 2009 6:20 pm ]
yeh mate.
they are great, im going to buy some also.
12 inch deep dish tyres 830au with tyres landed in Auz
unreal deal.
Author:  NG [ Wed Apr 15, 2009 7:11 pm ]
or you can go 12x5 deep dish & you don't need any body mods or new arches if you have some allready.
Author:  miniimports [ Wed Apr 15, 2009 7:38 pm ]
Post subject:  re rims
sounds extremely cheap considering superlites with falkens generally are around the $1100 mark
Author:  NG [ Wed Apr 15, 2009 9:09 pm ]
i just Bought the for the 12 x 5 deep dish rims with the Yoko A539's
come to $890 to my door in Qld.
no cutting guard no buying new guards.
here they are on a uk mini
6 days..
Page 1 of 3 All times are UTC + 10 hours
