Compliance for Rover MINI's https://www.ausmini.com/forums/viewtopic.php?f=2&t=52049 |
Page 1 of 3 |
Author: | travhill_78 [ Sat Apr 11, 2009 6:01 pm ] |
Post subject: | Compliance for Rover MINI's |
What is needed for compliance in a Rover Mini? Does a roll cage help for side impact etc? |
Author: | Harley [ Sat Apr 11, 2009 6:04 pm ] |
Buy a complied one already. Ooh look, heres one, and its a steal at that price! http://www.ausmini.com/forums/viewtopic.php?t=49713 ![]() |
Author: | BALLISTIC [ Sat Apr 11, 2009 7:28 pm ] |
Post subject: | Re: Compliance for Rover MINI's |
travhill_78 wrote: What is needed for compliance in a Rover Mini?
Does a roll cage help for side impact etc? Roll cage ..... No. Needs the kit fitted to the door and a few other bits and bobs......cant think of them at the moment......but if you can buy one thats already done im sure it would be more cost effective especially if you are planning on changing the engine at a later date...... |
Author: | Harley [ Sat Apr 11, 2009 7:39 pm ] |
You need intrusion bars fitted into the doors, and retractable seatbelts fitted into the back, both involve a bit of cutting and or welding. A handbrake warning light needs to be fitted, and in some stated new tyres and brakes too. There's other little things of course as well. If the car is left hand drive that also needs to be converted over. |
Author: | Fat Boy Dave [ Sun Apr 12, 2009 6:48 am ] |
You forgot a child seat restraint, rear windscreen mounted stop lamp. Potentially new windscreen (depending on the thickness of the glass). Though I guess these are minor compared to putting in side intrusion bars. |
Author: | speedy [ Sun Apr 12, 2009 10:14 am ] |
+ Add "unleaded only" flap to fuel tank neck, and in depending on how anal the inspector is, need to fix head rests to seat and / or remove wire from sun visors. PITA. And people wonder why Brickworx has moved on from this game.... |
Author: | EST-071 [ Sun Apr 12, 2009 10:54 am ] |
speedy wrote: + Add "unleaded only" flap to fuel tank neck. Fat Boy Dave wrote: rear windscreen mounted stop lamp.
Mine has neither of these and is rego'ed in NSW. The things that have been done are; Door intrusion bars Retractable seat belts in rear also new belts in front Child restraint points in rear (rear parcal shelf has to be strengthened) Hand brake light Engine tuning placard under bonnet Tyre placard in boot Plus you will need the normal things for rego like brakes, lights, windscreen ect. I think that is all that has been done to mine. Cheers Pete P.S Also have a read of Maxi23's post about transferring rego to NSW X To NSW Rego Transfer (Rover Mini, NSW Resident) - FAQ |
Author: | greyghost [ Sun Apr 12, 2009 11:56 am ] |
speedy wrote: + Add "unleaded only" flap to fuel tank neck, and in depending on how anal the inspector is, need to fix head rests to seat and / or remove wire from sun visors. PITA.
And people wonder why Brickworx has moved on from this game.... no longer required, as you can only buy unleaded at the pump. |
Author: | miniimports [ Sun Apr 12, 2009 1:14 pm ] |
Post subject: | re compliance |
would be best to speak to an engineer who can perform certifcation for compliance, i dont know any myself,would be great though if somebody whos done there own compliance in victoria lets us know who they have used as there are a few of you out there,last quote we got to do the job was $1800 a year ago with us supplying a cat back exhaust,cheers |
Author: | Jules [ Tue Apr 14, 2009 11:36 pm ] |
greyghost wrote: speedy wrote: + Add "unleaded only" flap to fuel tank neck, and in depending on how anal the inspector is, need to fix head rests to seat and / or remove wire from sun visors. PITA. And people wonder why Brickworx has moved on from this game.... no longer required, as you can only buy unleaded at the pump. Well you would think so wouldn't you, but last time I looked the small filler neck and unleaded label were still in the book as a requirement! Where's the logic in that? |
Author: | greyghost [ Wed Apr 15, 2009 4:53 pm ] |
yes but you live in QLD, and non of the rules up there make sense. ![]() |
Author: | Morris 1100 [ Wed Apr 15, 2009 6:02 pm ] |
Dotars have removed some outdated ADRs from the books. But as registration is under state control it is up to each state to enforce the rules. But... If you could afford a Constitutional lawyer you could challenge the state rules under the Australian Constitution (I can't think of the section number but it is the bit about Federal laws over-riding State laws) It is quite easy really! ![]() |
Author: | Harley [ Wed Apr 15, 2009 6:08 pm ] |
Morris 1100 wrote: If you could afford a Constitutional lawyer you could challenge the state rules under the Australian Constitution (I can't think of the section number but it is the bit about Federal laws over-riding State laws)
Is it the vibe? ![]() |
Author: | Morris 1100 [ Wed Apr 15, 2009 6:40 pm ] |
Harley wrote: Morris 1100 wrote: If you could afford a Constitutional lawyer you could challenge the state rules under the Australian Constitution (I can't think of the section number but it is the bit about Federal laws over-riding State laws) Is it the vibe? ![]() Yep. ![]() |
Author: | EST-071 [ Wed Apr 15, 2009 8:05 pm ] |
Jules wrote: greyghost wrote: speedy wrote: + Add "unleaded only" flap to fuel tank neck, and in depending on how anal the inspector is, need to fix head rests to seat and / or remove wire from sun visors. PITA. And people wonder why Brickworx has moved on from this game.... no longer required, as you can only buy unleaded at the pump. Well you would think so wouldn't you, but last time I looked the small filler neck and unleaded label were still in the book as a requirement! Where's the logic in that? Might be in QLD, but mine is rego'ed in NSW without them. Cheers Pete |
Page 1 of 3 | All times are UTC + 10 hours |
