guiding rear van wiring thr beaver panel.. https://www.ausmini.com/forums/viewtopic.php?f=2&t=52086 |
Author: | floss [ Mon Apr 13, 2009 8:19 am ] |
Post subject: | guiding rear van wiring thr beaver panel.. |
IT is funny but this has to be the most annoying job I have had to do on my mini yet. I have tried to thread a piece of fence wire through and then pull a string through with that but it gets stuck/wont go forward/wont go back/drives me round the bend. Anyone know a magical way that does not involve me getting out any ryobi products? Cheers David |
Author: | Kennomini [ Tue Apr 14, 2009 10:13 pm ] |
Don't use Ryobi get a Makita ![]() |
Author: | Trixitrine [ Tue Apr 14, 2009 10:41 pm ] |
have you tried removing the fuel tank? |
Author: | Tombo [ Tue Apr 14, 2009 10:45 pm ] |
Any wire, string etc you join together tape it up smooth and lube it with oil. Works on BA Falcon bonnet cables (i don't remove the guard, i cheat) |
Author: | Convertible Mini [ Wed Apr 15, 2009 7:30 am ] |
Post subject: | Puttin wires through |
For putting wires through gaps like this is always best to use thet piece of plastic strip that fits in the end of tongue and groove boards. It is stiff and also flexible. Drill a hole in the end of it and tie the wires to it andis it a a pull through. But what you are doing would be best to lower the Fuel tank as the wires have to be cliped in place and not left hanging to rub and wear and eventually short out. Especially around the Fuel tank. |
