It is currently Tue Jul 29, 2025 3:02 am
PostPosted: Thu Apr 16, 2009 5:35 pm
Hey,
How can I Minimise the cabin noise in my 1978 Mini Clubman, 1032cc? I have a sports Lukey, exhaust on it running straight down the middle and extractors. I put a resonator on it get rid of a lot of droan. I think a lot of the noise is now coming from the engine, either way it is far too loud. How can i minimise noise?
Any help will be appreciated!
Will
Club Man
PostPosted: Thu Apr 16, 2009 5:39 pm
Tomboss Breweros
Is the bulkhead trim there?
kimini wrote:
Jimmyinamini wrote:
PostPosted: Thu Apr 16, 2009 5:40 pm
Go back to a stock exhaust.
Dynamat in the car may help too.
PostPosted: Thu Apr 16, 2009 5:43 pm
Mine is pretty bad as well. Its got no bulkhead covering. And no undercarpet sound deadening at all. I also decided itd be a good idea to pull most of the hessian sacking type stuff out.
Putting sound deadening under the carpets would be a good start. And on the bulkhead.
PostPosted: Thu Apr 16, 2009 6:20 pm
i put two layers of carpet underlay in my car, and then moulded carpets.
The molded carpets are thick, so three layers takes ALOT of noise out.
Only problem is need to watch how think it is around your pedals.
PostPosted: Thu Apr 16, 2009 6:59 pm
i dynamatted the whole floor and got it painted the same colour as the car and in the boot to.id advise that i got my for 14.50 a sheet ended up costin me 145 all up. then you could fit underlay over the top and moulded carpet and should be good.
TUCK3R
PostPosted: Thu Apr 16, 2009 8:01 pm
Had same problem in mine on 2 inch. Put in a straight through hot dog before the lukey. It does the trick, reduces the noise about 20 decibels, honest, and no performance difference
PostPosted: Thu Apr 16, 2009 8:04 pm
I can't hear my exhaust, the 45 Dellorto induction noise with 38mm chokes drowns it out.:mrgreen:
PostPosted: Thu Apr 16, 2009 8:07 pm
High heel ninja
Its a mini, deal with it.
Doogie
PostPosted: Thu Apr 16, 2009 8:18 pm
Bigger speakers are cheaper and easier than soundproofing. :wink:
PostPosted: Thu Apr 16, 2009 8:29 pm
Will
Buy a Prius or harden the **** up - the noise of an A-series is golden - the only reason we quieten them done is to please the fuzz
DOZ
PostPosted: Thu Apr 16, 2009 8:35 pm
true very true
First you get the money,then you get the power,then you get the Mini.
PostPosted: Thu Apr 16, 2009 8:55 pm
blokeinamoke wrote:
PostPosted: Thu Apr 16, 2009 9:07 pm
Geez, give a guy a break....I'm pretty sure he wasn't looking for prestige car like interior noise levels...:roll:
Sound deadening trim behind the air filter removes a fair amount of noise, as does ensuring there is some deadening behind the dash trim and carpet up under the dash behind the heater. It's easily forgotten.
Once you get the sound deadening sorted out, it removes most of the high frequency mechanical clatter and leaves you with an awesome exhaust note.
Give Ash some flowers Nick .
Come on guys, tone it down it & behave. Will is asking a serious question.
