It is currently Mon Jul 28, 2025 12:43 am
Post new topic Reply to topic  [ 33 posts ]  Go to page 1, 2, 3  Next
Do you run a brake booster?
Yes 36%  36%  [ 16 ]
No 64%  64%  [ 29 ]
Total votes : 45
 Post subject: Brake booster
PostPosted: Fri Apr 17, 2009 12:15 pm
Hi,
Just wondering who runs a brake booster on their cooper s discs. All i really know of them is that they amplify your brake pressure so you dont need to hammer the brake pedal as hard as without a booster. Is that right? Any info would be great as im looking to buy disc brakes very soon.
Joe
PostPosted: Fri Apr 17, 2009 12:18 pm
Need Manifold with Vacuum outlet
Need to put it somewhere
Need to hope the diaphram don't leak
Need to have new lines made up
Need to not fit one
- 1962 Beige Delight club car, Rebuilding.
- Motorkana Special
- Minor Mishap, 1958 Morris Minor
-- Last ever Tea Lady at Longbridge--
PostPosted: Fri Apr 17, 2009 12:26 pm
They work for many years when they are rebuilt. Only problems come when you grab one from the wreckers and put it in. Boosters are very reliable otherwise.
They do clog up the engine bay somewhat, and will help braking as well...but minis will stop nicely on discs with a nice set of quality pads in any case...
PostPosted: Fri Apr 17, 2009 12:54 pm
we run two boosters on the fang one out of an 1800 for the front and a mini one for the rears
PostPosted: Fri Apr 17, 2009 1:27 pm
Once you become adjusted to unboosted mini disc brakes you will love the pedal feel. It's never quite the same with a booster, and unless you are very slight or feeble you should have no problem pushing hard enough to lock them up.
PostPosted: Fri Apr 17, 2009 1:45 pm
Absolutely!!
Unboosted discs are excellent! Much better feel, i just have to remember when swapping into the mini from the modern car that i need to press a wee bit harder on the middle pedal :wink:
PostPosted: Fri Apr 17, 2009 2:20 pm
We don't run one on our S powered Moke.
It has always stopped fine in all the motorkhanas we've done. :D
Julie.............
PostPosted: Fri Apr 17, 2009 2:22 pm
I run my Mini without, but I'm putting one in the wife's 1412 van when I build it.
Why?
1. Coz I have a recoed one already on the shelf.
2. She likes the feel of modern car brakes... :wink:
Last edited by drmini in aust on Fri Apr 17, 2009 2:22 pm, edited 1 time in total.
Matt68 wrote:
Absolutely!!
And remind mechanics etc if they get into it that it is a real car and not some soft hyundai ....
Had mini's with a booster and without , I prefer it without just because it's what I'm used to and like .
PostPosted: Fri Apr 17, 2009 3:45 pm
Good advice, some newer mechanics have probably never driven a car with unboosted discs :lol:
The only mechanics who touch my minis are those that own minis themselves!!!! :D :D
PostPosted: Fri Apr 17, 2009 3:51 pm
the diaphragm failed on my booster a few years ago, I took it off, and bought the bits to fix it but haven't bothered
more important when fitting disks is to change your rear brake cylinders to 5/8" bore, otherwise you will have rear wheel lockups in hard braking conditions
PostPosted: Fri Apr 17, 2009 3:55 pm
Why wood you ruin the surprise?
- Motorkana Special
PostPosted: Fri Apr 17, 2009 5:04 pm
Both my Mini's run them. I prefer the boosted feel, but as said not necessary just another luxery really.
My current project has 4 pot vented discs on the front but I won't be running a brake booster as the car has dual brake lines so a single brake booster wouldn't work and setting them up boosted requires either too much room or is too complicated. So we'll see how that feels.
PostPosted: Fri Apr 17, 2009 5:13 pm
I hardly run brakes let alone boosted ones
PostPosted: Fri Apr 17, 2009 5:29 pm
Mien
Hahaha........they're minis after all! :lol:
I honestly think that I had boosted brakes, I wouldn't be able to stop. WIth 4 1/2 " wide Falkens on the front, I skid bloody every where as it is.
