It is currently Thu Aug 14, 2025 8:12 pm
 Post subject: MK1 DRAIN PIPES.
PostPosted: Mon Apr 20, 2009 5:45 pm
im finding them hard to get in under the door.
any one had problems?
I've bought some from mini spares now so ill see how they fit? now & be back.
dam pipes.!!!
PostPosted: Mon Apr 20, 2009 6:16 pm
Fit from inside the door. One end of tubing fits over the tube located at each end of the sliding window drain channel and the other ends fit inside the tubes located at the bottom of the door. Tube should end up flush with the bottom of the door.
PostPosted: Mon Apr 20, 2009 6:23 pm
yeh i know that.
getting it in is a bitch!
i cant seem to slide it over.
maybe put the pipe in boiling water?
i cant seem to fit it over the pipe up in the door.
PostPosted: Mon Apr 20, 2009 10:45 pm
I stuck the ends in boiling water and sprayed some window cleaner on the tubes.
Still a bugger of a job though.
Image Image
PostPosted: Mon Apr 20, 2009 10:50 pm
window Cleaner?
there seems there is not much space up the top between the wall of the pipe & door.
tight fit!
Users browsing this forum: Barkfast, Bing [Bot] and 184 guests
