Any bright ideas
https://www.ausmini.com/forums/viewtopic.php?f=2&t=52418
Author:  Wombat [ Thu Apr 23, 2009 8:21 am ]
Post subject:  Any bright ideas
The front nut on the top hinge, body side is stripped or something - turns but won't undo - not sure if the whole thing maybe turning - tight as working in there, tried leavering the hinge away from the body while turning but no good. Any other ideas?
Author:  gafmo [ Thu Apr 23, 2009 8:23 am ]
can you get a flat screw driver under the nut...i know its a impossible possition :roll:
Author:  drmini in aust [ Thu Apr 23, 2009 8:24 am ]
If you can get in there, MIG tack weld the nut to the stud, then screw the lot out. :wink:
I replaced all the studs in mine, I bought 1/4 UNF bolts from Supercrap and cut the heads off, to length. Then Loctited them into the hinges.
Author:  Wombat [ Thu Apr 23, 2009 8:26 am ]
That was going to be my next question :lol:
Author:  drmini in aust [ Thu Apr 23, 2009 8:33 am ]
Be very careful with boot hinge studs when you do those. They are only screwed a few turns into the ALLOY hinges, and strip real easy. :evil:
No room for a helicoil, so I made new bullheaded studs up- 5/16UNC coarse thread into the alloy, 1/4 UNF the rest.
Author:  Wombat [ Thu Apr 23, 2009 12:15 pm ]
It's the stud that is turning and obviously stripped - Think I'll have to get in there with a dremel and try and split the nut.
Author:  gafmo [ Thu Apr 23, 2009 12:49 pm ]
or the thread inside the hinge
are all the other bolts off. Maybe swing the door out al little and rest it on a milk crate and it may be just enought pressure on the nut or thread for it to catch and come out just like those pesky ball joints
Author:  Tombo [ Thu Apr 23, 2009 12:56 pm ]
I've had them strip out of the hinge before.
The new range of helicoil kits have different lenth inserts, the shortest one is about 5 turns, I recoiled mine no problems with 1/4 unf :wink:
I like the tacking of the nut to the stud idea.
Author:  simon k [ Thu Apr 23, 2009 1:47 pm ]
am I confused?
the stud is stripped in the hinge with the nut still on it, so the nut and the stud is turning as you try to undo it?
got room to grab the nut with some vice grips and just pull the stud straight out, or pull the hinge off it from the outside?
it won't take much to lunch the rest of the thread
Author:  Wombat [ Thu Apr 23, 2009 2:29 pm ]
simon k wrote:
am I confused? Huh!
the stud is stripped in the hinge with the nut still on it, so the nut and the stud is turning as you try to undo it? Correct
got room to grab the nut with some vice grips and just pull the stud straight out, or pull the hinge off it from the outside? Tried multigrips - will give it a go with vice grips - got to be careful - don't won't to damage the Duco :roll:
it won't take much to lunch the rest of the thread Not to fussed about that -will be replacing the stud anyway
Author:  64cooper [ Thu Apr 23, 2009 7:47 pm ]
David
take an angle grinder with 2mm cutting disk and cut the hinge off through the middle of the bolt. I've got plenty of spare hinges so you are welcome to half of the hinge you need. Do as the doc says and locktite some new studs in.
