bypass hose.....
https://www.ausmini.com/forums/viewtopic.php?f=2&t=52475
Author:  Blunder [ Fri Apr 24, 2009 3:17 pm ]
Post subject:  bypass hose.....
Currently got the water pump off my car so while evrything is apart going to replace the bypass hose(currently has the confoluted type) with a solid piece of hose...
What length should it be? thanks
Author:  drmini in aust [ Fri Apr 24, 2009 3:20 pm ]
Sit the pump on there, cut the hose about 1mm longer than the total visible room for it.
Use 1/2" heater hose, or 15/32 vacuum hose (stronger). :wink:
