Caponix wrote:
ive also noticed there is also some resistance on the RHS carby throwt and requires a bit of effort to push up (in comparison to the LHS)
that's your number 1 problem right there, the car will never be right unless the carbs are in sync
Caponix wrote:
also from my previous threads discussion some people have suggested that the car is only running on 1 carby
they were right - if it takes effort for you to push the dashpot up, then it takes the same effort for the motor
first thing to do, and before fiddling with worn shafts, which really only effect the idle, is to get the pistons acting the same
take the dashpots off both carbs, and take the pistons out - at this point, make sure you keep the parts for each side identifiable - a texta mark, whatever
clean the insides of the dashpots, and the outer rim of the pistons with some petrol or other solvent, get them really clean. Slide the pistons inside the dashpots and check that they feel clean and not sticking.
if they're sticking or feel gritty, get some kitchen ajax powder, make a thick paste and smear some inside the dashpot and around the piston rim, put the piston in and gently work it in and out and around - all the way in, and out, turning it as you go - then clean the ajax out, and check that it's moving freely. When you do this - be gentle with it, it's soft alloy, doesn't take much to clean it up.
When you've got both of them moving freely, get some blu-tack, and if the pistons have holes in the bottom of them, plug the holes up (remove the blu-tack after you've done this bit). Put the pistons inside their respective dashpots, hold them up the right way with the piston all the way up inside the dashpot, and let it fall down into your hand - DON'T DROP THEM ON THE FLOOR/BENCH/ANYTHING!
if they fall at very different rates, swap the pistons over, and try it again - mix and match parts that give you both pistons falling at the same rate.
When you've done that, put them back together and see what's what
did I tell you that I won a
trophy?
