headgasket wrote:
You can see where it has blasted out around the cap and the engine bay smells like oil.
How can I seal the oil cap to keep the vapours in?
your problem is that the vapours have nowhere else to escape, which would also be why you've been getting oil leaks - the engine needs to breathe.
If you've got the rocker cover with the bulge thingy on top, check it's not blocked, and check where it's connected to isn't blocked
If you're getting really excessive breathing vapours, then you're getting piston blowby and your compression rings have had it - I know - I've had it twice in the last 12 months
headgasket wrote:
Edit: question 2: what thread size are the rear bumper mounting holes (78 clubman)? Someone's painted over them and I need to retap and mount the bumper properly. (After some drunks tried to lift my car by the bumper while I was trying to sleep inside -_-)
they're going to be either 1/4 UNF or 5/16 UNF - one of the two
did I tell you that I won a
trophy?
