brake line question https://www.ausmini.com/forums/viewtopic.php?f=2&t=52863 |
Author: | Fiji [ Mon May 04, 2009 1:10 pm ] |
Post subject: | brake line question |
can't get the brake line (the rubber one) off the front wheel cylindar . is there a tip ,, idon't want to bugger the hose up with the way that im doing it ![]() any help would be awesome fiji |
Author: | rampage101 [ Mon May 04, 2009 1:11 pm ] |
I take it your using the correct sized spanner? |
Author: | sgc [ Mon May 04, 2009 1:28 pm ] |
One trick you can use is to unscrew the wheel cylinder from the backplate, bring the hose through and unscrew the wheel cylinder from the hose, instead of the hose from the cylinder. Make sense? |
Author: | Booglie [ Mon May 04, 2009 1:31 pm ] |
you will have to undo the big nut where the hose goes into the subframe as well as the solid brake line, or take the brake part (caliper/slave cylinder) off the hub. |
Author: | Fiji [ Mon May 04, 2009 2:31 pm ] |
k giving it a o now thanks |
