It is currently Sun Aug 17, 2025 10:55 am
 Post subject: Back on the Road
PostPosted: Fri May 15, 2009 12:56 pm
Ok peeps,
Getting back on the road after all the hassles :D. So heading for Goondiwindi Tomorrow. St George on the Wednesday. Across the border into NSW on the Sunday.
So finally, maybe on the Saturday, BBQ somewhere in St George.
Any mini peeps in Bourke, then im passing through in the following week.
PostPosted: Fri May 15, 2009 1:27 pm
good luck ,,, hope the journeys is hassel less
PostPosted: Mon May 18, 2009 3:13 pm
made it to st george, ill have some pics of lots of stuff soon, and some text to go with it. I'll be in the area till sunday, then im heading for Lightning Ridge.
Clutch has now got an oil leak, slipping and shuddering again :evil:
But i have parts. :lol:
Other than that, Bobs yer aunty.
PostPosted: Mon May 18, 2009 3:17 pm
look forward to the pics.
Mini Clubman 72 aka Juno 998cc
PostPosted: Mon May 18, 2009 5:58 pm
You could squirt some CRC Brakleen into the clutch via the little timing mark hole and the starter hole (after removing the starter) This may slow the slipping down a little.
Make sure the drain hole in the bottom of the clutch housing is not blocked.
PostPosted: Wed May 20, 2009 3:06 pm
Thanks for the CRC tip 1100, its started to slip alot now. Rev it and it slips, once its been on road for 10 mins its fine, seems to dry out.
http://www.googajoob.com/v3/index.php?m ... ticleid=26
some pics and some text.
Users browsing this forum: No registered users and 306 guests
