It is currently Wed Jul 23, 2025 7:23 am
 Post subject: Loom Diagram
PostPosted: Tue May 05, 2009 1:17 pm
I'm rewiring Marcia while I have a little time. This is how I'm going to hide as much of the wirering as I can. Luckily what came out was labled but I want to upgrade a few doggies in the loom
I have my trusty :lol: Haynes but as you could imagine none of them are perfect and the one I'm going by I have written all over it :roll:
I want to find a program I can redo a diagram of my loom :wink:
PostPosted: Tue May 05, 2009 1:27 pm
What mini is it? Alternator or genny?
 Post subject: Re: Loom Diagram
PostPosted: Tue May 05, 2009 1:31 pm
Try that QuickCAD I gave you.
I am an ex- draftsman and I hate CAD... :evil:
I have tried QuickCAD, DesignCAD 3D, Autocad and Inventor. I can't use any of the bastards... you need to have an employer who will pay you to sit there while you spend a year or more learning them.
I can use CADKEY 6 (for DOS) but it's now obsolete and I have no copy. :cry:
/end rant
I now use pens and paper to draw, then scan the bugger.:mrgreen:
<edit> I do have a proper diagram for roundy Oz van, I'll scan it for ya.
PostPosted: Tue May 05, 2009 1:35 pm
tried the back of the Leyland manual
PostPosted: Tue May 05, 2009 1:44 pm
yep remembered about The CAD program and Im trying it now. Yep I like the Rule and Pencile I us to do also but my hand writing is just as bad as my spelling :lol:
The thing is I will be adding a few things and want to record how the digram will be changed
mainly fuse box relays dials
Cheers kev it may be better than the one I have in the 2 books I have :roll:
PostPosted: Tue May 05, 2009 2:22 pm
Is it the wiring diagram you want or a loom 'map'?
When I got a new 850 loom I measured a drew a 'map' of the loom with distances between each branch and colours and lengths of wires in each branch. If that would be of help I can send you a copy of the file in PDF.
David L
PostPosted: Tue May 05, 2009 3:52 pm
That could help David
PostPosted: Tue May 05, 2009 8:29 pm
Check your email :wink:
David L
PostPosted: Wed May 06, 2009 8:08 am
Cheers for that David, not exactualy what I was looking for but will come in very handy. Also just checking that came throu as a Word Doc.
I Believe I have all the Front and Rear lights and Blinks correct, Switchs wipers, dash & fuse box.
Relays "new era"" for the lights I just have to work out and the 8 fuse box specialy for the Mains. The thing that gets me are the Mains "Brown wires" are differantly wired for every style :roll: :lol:
Need to get some new wires as some have earthed at some time
PostPosted: Wed May 06, 2009 8:11 am
I'll drop by and show you how I wired my New Era relay in. Easier than describing it. :wink:
PostPosted: Wed May 06, 2009 8:32 am
hehe Ill be here all day
also on relays have I got this correct
Pin
30 - 12v Power / Starter Solenoid
85 - Earth
86 - Switch of Horn etc
87 & A - Horn/fuel pump
PostPosted: Wed May 06, 2009 8:49 am
First file I came across - couldn't be bothered searching for the PDF files :roll:
David L
PostPosted: Wed May 06, 2009 8:50 am
:lol: no trouble David :wink: would have taken youy some time to do it also :shock:
Users browsing this forum: Bing [Bot], Wolfgang and 85 guests
