What size are Mini spot welds?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=52935
Author:  Wombat [ Wed May 06, 2009 12:27 pm ]
Post subject:  What size are Mini spot welds?
I've seen 5/16" and 3/8" cutters advertised and wonder what size you need for Minis and Mokes ?
Author:  drmini in aust [ Wed May 06, 2009 12:38 pm ]
I think from memory 5/16" is the size... :wink:
Author:  sitnlo62 [ Wed May 06, 2009 1:53 pm ]
David,
I would say it depends on how good you are at finding the centre of the spot!
5/16" would be good if you are sure of hitting the centre every time!!
Dave
Author:  Wombat [ Wed May 06, 2009 2:24 pm ]
sitnlo62 wrote:
David,
Dave
The ones I'm looking at have a retractable centre point - line it up then push down to engage the cutters
Author:  Angusdog [ Wed May 06, 2009 2:30 pm ]
I haven't heard anything good about those, but some pretty bad press, mainly in the life of the cutters. Spot weld drills, i.e. a drill with a little drill centre and then flat cutting area out to the diametre, are much better. Frost in the UK have them but you may be able to find them locally.
I wouldn't worry about finding the centre exactly each time, as you'll be able to break the little weld that remains; it won't be very strong.
Author:  jbeenz [ Wed May 06, 2009 2:36 pm ]
I would have said inconsistent at best..
Author:  Mick [ Wed May 06, 2009 3:15 pm ]
The retractable centers are crap. They jam up...
Author:  sitnlo62 [ Wed May 06, 2009 3:15 pm ]
Wombat wrote:
sitnlo62 wrote:
David,
Dave
Thats fair enough David but you have to put that center point somewhere.
The point is that you have to decide where centre is, not always easy.
Dave
Author:  mickmini [ Sun May 10, 2009 2:37 am ]
I had to get a 8mm puntlaasboor because they don't believe in the empire here :roll:
It did the drip rails just fine. :)
