Mini Brake light switch?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=52939
Page 1 of 2
Author:  NG [ Wed May 06, 2009 3:12 pm ]
Post subject:  Mini Brake light switch?
what do i need & where do they go.
the white electric one?
it's rover powered mini.
Author:  TheMiniMan [ Wed May 06, 2009 3:15 pm ]
Probably under the dash,,, up at the pedal assembly
Author:  Harley [ Wed May 06, 2009 3:17 pm ]
Rover engine doesn't mean jack.
What year is the pedal box you have?
Author:  NG [ Wed May 06, 2009 3:20 pm ]
ah sorry!! Harley.
it's a rover break booster pedal set up.
mostly everything in my mini are rover parts.
Author:  Harley [ Wed May 06, 2009 4:30 pm ]
If you have the rover booster, then you need the rover pedal box to suit.
The white plastic switch will do the job, it'll probably work easier with the wiring loom,
but the 60's pressure switch will do the job too.
Author:  weevel [ Wed May 06, 2009 4:43 pm ]
If it's a full Rover set up down at the pedals, It's this one:
http://www.minispares.com/Product.aspx? ... FLOOR%20...
I had mine break a few months back, it sits in a little bracket behind the brake pedal, 2 minute job to replace after waiting 2 weeks for it to arrive from UK.
Author:  NG [ Wed May 06, 2009 4:48 pm ]
I have the rover booster & the rover pedal box.
as far as i can remember.
but if i need to buy a 60's one can some one link me to what they look like?
i bought the above white one for $10 today.
Author:  drmini in aust [ Wed May 06, 2009 4:50 pm ]
The 60's pressure switches they sell in the 00's are not well made in whereverland, they have a poor reliability record.
I got 3 months from one new one, then 3 weeks from another. NO MORE...
:evil:
IMO a mechanical switch is the only way to go- and the bloke behind you will appreciate the extra warning that you have tossed the anchors out. :D
Author:  NG [ Wed May 06, 2009 4:53 pm ]
mechanical switch>? whats that look like.
Author:  drmini in aust [ Wed May 06, 2009 4:55 pm ]
see pic 2 posts up-...^^^
Author:  drmini in aust [ Wed May 06, 2009 4:56 pm ]
That is same as a late Clubby or Moke switch, you can buy here.
BTW the nut for it is just 1/2" UNF. :wink:
Author:  NG [ Wed May 06, 2009 5:00 pm ]
ok great mate.
that's what i bought.
I'm not sure where it go's where it sits under inside or under the brake pedal.
i cant really work out where under that pedal but I'm sure it cant be hard
just hard when it's there in the first place!
Author:  Boyracer [ Wed May 06, 2009 6:23 pm ]
The switch sits sort of up the top above the pedal. The pedal lever hits it when you put your foot down.
Author:  drmini in aust [ Wed May 06, 2009 6:57 pm ]
Boyracer ,
Are you sure of that? On all pre-Rover Minis (and other cars) it's the other way, it comes on when the pedal is pushed away from it.
Have another look... :wink:
Author:  Harley [ Wed May 06, 2009 7:12 pm ]
Rovers are as the doc says, as are 99% of all other cars.
:D
