slight knocking noise
https://www.ausmini.com/forums/viewtopic.php?f=2&t=52970
Page 1 of 2
Author:  tinymorris1969 [ Thu May 07, 2009 7:06 pm ]
Post subject:  slight knocking noise
ive noticed it a little while now and my first thoughts were it must be the steering rack cause its loose. well now the noise has gotten louder and im starting to think it may be something else.
the noise only happens when i turn left slightly and when i i slow down. when i brake i can feel it in the pedal and it knocks at the same pase as the vans movement. so now im not to sure cause the rack wouldnt cause a knock in the brakes and travel through the pedal would it??
im starting to thinking maybe the uni on the left hand side is loose and making the noise.
any thoughts?
Author:  Morris 1100 [ Thu May 07, 2009 7:08 pm ]
Take a look at the rack, reach under the car and grab the left hand tie-rod near the rack and try shaking it up and down. See if it knocks.
Author:  tinymorris1969 [ Thu May 07, 2009 7:12 pm ]
yeah done that and it knocks. thats what lead me to think it was the rack at the begining... but i cant work out why its coming through on the brake pedal...
Author:  mattsmadmini [ Thu May 07, 2009 7:14 pm ]
cha...
this was me a day or 2 before my trip to wagga.... passenger side tie rod thread had 1 and a half spins left on it till it was off... :shock: all cleared up now... and no knock :D
Author:  tinymorris1969 [ Thu May 07, 2009 7:16 pm ]
hmm was ur knock coming from inside the rack though??
Author:  TUCK3r [ Thu May 07, 2009 7:23 pm ]
do you have 14 dollars go and get a pedders safety check they will have trained person in suspension to diagnose the problem for you.Then either pay them or a mechanic to fix it.
Cheers TUCK3R
Author:  drmini in aust [ Thu May 07, 2009 7:23 pm ]
If your rack is loose just buy some bits and fix it. It's not rocket science... :lol:
All the usual wear bits for Oz racks are still available.
Author:  Morris 1100 [ Thu May 07, 2009 7:33 pm ]
When you apply the brakes the wheels want to toe-out.
When you apply power it wants to toe-in.
So as you brake it knocks.
Inside the left hand side of the rack is a bush that wears out, it takes the braking load of the left wheel and knocks. (the right hand side has the pinion and tensioner to take the load)
Author:  drmini in aust [ Thu May 07, 2009 7:41 pm ]
The original Oz rack bushes were felt, but now you can get either lurethane or nylon ones.
The lurethane bush is made by Nolathane, p/no 41039. I got from Pedders.
Karcraft carries the nylon one.
Author:  tinymorris1969 [ Thu May 07, 2009 7:45 pm ]
ahhh makes sense.. i was told by mini spares that the racks in the early model clubbies arent repairable.. they are pretty much a replacement unit..
ok i just wanted a second opinion on it.. cause first thought and diagonsis was the rack is buggered and problem solved when i replace the rack. but when the brake thing started to happen along with being involved with 3 near misses at the same time sorta jumbled my head abit and has now got me second guessing myself..
so are the early model racks repairable then??
Author:  tinymorris1969 [ Thu May 07, 2009 7:46 pm ]
Cheers TUCK3R
are u taking another dig a my mechanical abilities??
Author:  Morris 1100 [ Thu May 07, 2009 7:48 pm ]
They are all repairable, you just need to fit the right bits.
are u taking another dig a my mechanical dis-abilities???
:mrgreen:
Author:  drmini in aust [ Thu May 07, 2009 7:51 pm ]
They told you not, it's easier to sell you a late model one. :lol:
Note the Oz racks are all the same.
But rack is 1/16" larger diameter than UK, and UK rack bushes etc do not fit it.
Use oil in it after rebuild, if you want it to last. All the grease filled ones I have ever stripped were buggered by lack of lube.
Leyland decided to use grease, the rack maker (Cam Gears) advised against it- they say top them up with gear oil.
Author:  TUCK3r [ Thu May 07, 2009 7:53 pm ]
Cheers TUCK3R
no way! i thought if you wanted a second opinion go see pedders and you always say you have no time to do things so i thought it be easier to pay some one else to do it.
Author:  1310/71 [ Thu May 07, 2009 8:46 pm ]
Cheers TUCK3R
Some of the KMart tyre and brake centres can also do suspension work :D
KB
