gearbox cleaning https://www.ausmini.com/forums/viewtopic.php?f=2&t=52981 |
Author: | Leighton [ Thu May 07, 2009 9:26 pm ] |
Post subject: | gearbox cleaning |
hey, im just wondering if i can clean the gearbox out without taking out or ruining the bearings/ gears, as it has been sitting around for a while and i dont want crap through a rebuilt engine do i use kero? cheers leighton |
Author: | drmini in aust [ Thu May 07, 2009 9:33 pm ] |
Sorry but you will not get ALL the crap out unless you strip the gears out. Even if you do remove the layshaft, cluster gear and oil pickup + strainer, crud hides in the nooks and crannies under the mainshaft gears. Not worth the risk, with a new/rebuilt motor up top. I'd pull the gears out, diff too. Also it lets you check the condition of layshaft and all the bearings. I just did up an A+ box, it looked OK from above, but both the plastic cages in the big mainshaft bearing had disintegrated, bits were spread all over the box. And the diff pinion had lost a tooth because of it. The diff pin and planet gears were knackered, too. Sure it might cost you a few bob to be sure, but it's worth it for peace of mind and reliability. |
Author: | John Smidt [ Thu May 07, 2009 9:38 pm ] |
drmini in aust wrote: Sorry but you will not get ALL the crap out unless you strip the gears out.
Even if you do remove the layshaft, cluster gear and oil pickup + strainer, crud hides in the nooks and crannies under the mainshaft gears. Not worth the risk, with a new/rebuilt motor up top. I'd pull the gears out, diff too. Also it lets you check the condition of layshaft and all the bearings. I agree it is possible that you will loosen up bits of Stuff that has settled in a hard mass and this will then be very bad for Oil pump bearings etc |
Author: | Wombat [ Thu May 07, 2009 9:39 pm ] |
Then when it's all stripped down and the Mrs is out for a couple of hours wack it in the dish washer on the pots and pans cycle - comes up nice ![]() |
Author: | Leighton [ Thu May 07, 2009 9:45 pm ] |
oh i see..... i have little money- (17 yr old student) and not much time (the whole thing must be finished by the 24th August) for HSC and i can only do the engine at school with 40 min periods 8 times a fortnight and the body etc is done at home. would cleaning it out with kero be atleast a short term fix? |
Author: | Mick [ Thu May 07, 2009 9:49 pm ] |
If by short term you mean you put it on the engine and run it anyway...then it may as well be long term.... |
Author: | drmini in aust [ Thu May 07, 2009 9:53 pm ] |
If you have or can borrow the tools, you will have it stripped in an hour or less. ![]() Why not get Ryan or someone down there to help you? No need to pull the mainshaft gears off, just wash the whole mainshaft assembly with degreaser or diesel when you get it out. You can leave all the gear selector forks etc in there too. I'm just afraid you new engine will end in tears if you leave dirt in there...... ![]() |
Author: | John Smidt [ Thu May 07, 2009 9:54 pm ] |
Mate bring it up to Mini king I will show you how to pull it down and we will clean it here for you, And help you put it back together, It Will only cost you for what ever parts you need |
Author: | Leighton [ Thu May 07, 2009 10:00 pm ] |
the markers have to see the engine running. so i guess it would have to be long term ![]() too much to do, not enough time. im intending to buy a 1275 and rebuild that eventually. ok so my real question is it worth using kero as a cleaning agent in the gearbox or leaving it as is? will i create more problems using kero by lifting up hard masses of "stuff"? |
Author: | drmini in aust [ Thu May 07, 2009 10:07 pm ] |
OK now I see your point.... If it is pretty clean really, I would take the side cover off, and slosh some diesel (NOT kero) though it. I find kero tends to leave gritty stuff behind. Then blow it all out with an air hose. Keep doing this until the diesel runs out clean. ![]() |
Author: | Leighton [ Thu May 07, 2009 10:19 pm ] |
John PM sent ( the generosity of people on Ausmini never ceases to amaze me) doc, thankyou for all your tips and input. Leighton |
