There is also an issue with "Centralisation" of the throw-out bearing & it`s carrier,,, the clutch cover change may have effected a slight miss-alignment of the throw-out bearing to the center of the crank
this was very prominant in later minis & the factory tried to cover the symptom up by producing the "self-centering" throw-out bearing carrier
The factory also had quite a number of warrantee claims over this problem & a whole heap of minis were taken back, & the cover was then centered using the factory cover centering tool, & the cover was then doweled to the primary case
soo,,, maybe you have shifted the center line of the throw-out bearing with the change in clutch cover
maybe a self-centering carrier is needed... or if you can sort a "Centering tool" then you can centralise the cover correctly & fit it all back up again nice & true to the crank centre line
a tiny bit off here & the tin hat assy wants to wobble when the throw-out bearing pushes slightly "off-set" against the tin hats thrust washer.
I don`t think i`ve ever typed sooo many "Center" words in one post ever before
If you have understood all what i`ve just typed then you`re well on your way to fixing the problem,,, if you havn`t understood then please don`t ask me to explaing it again,,, just way too many centers to type
