gasket poll!!!
https://www.ausmini.com/forums/viewtopic.php?f=2&t=52997
Page 1 of 2
Author:  mattsmadmini [ Fri May 08, 2009 12:10 pm ]
Post subject:  gasket poll!!!
woo..... a little off beat, just want others opinions...
Author:  Mini_Special [ Fri May 08, 2009 12:16 pm ]
3J or loctite 515 depending on location
Author:  weevel [ Fri May 08, 2009 12:17 pm ]
i did gasket and goo, but then i'd never done it before and there was goo everywhere. I still don't know if I did it right, but no leaks so far (5 months)
Author:  blue_deluxe [ Fri May 08, 2009 12:18 pm ]
I just use a gasket, but make sure both surfaces are as close to perfectly clean as they can be. Wont last as long but will be a lot easier to clean and replace with a new gasket.
Author:  Tombo [ Fri May 08, 2009 12:40 pm ]
I like loctite no. 3 aviation gasket sealer for water gaskets, use it sparingly on both sides of gasket and it's not too messy, cleans up ok on disassembly.
Author:  AEG163job [ Fri May 08, 2009 12:55 pm ]
unfortunately, Araldite takes too long to cure............................... :lol:
Author:  Mick [ Fri May 08, 2009 1:03 pm ]
I love that stuff....It should be the gasket alone is enough, but if you have it there then why not stick some on rather than hope that some clown hasn't jimmied the pump off with a crowbar and damaged the journal.
Author:  sgc [ Fri May 08, 2009 1:09 pm ]
I use a very thin film of Permatex gasket sealant, only because I tend to find the mating surfaces for water-jacket items are corroded and the gasket is no longer sufficient to seal by itself.
Author:  AEG163job [ Fri May 08, 2009 1:10 pm ]
Mick wrote:
I love that stuff
Good if used sparingly. Just need to remember when applying it to gaskets, your'e not icing a cake!
Author:  BALLISTIC [ Fri May 08, 2009 1:21 pm ]
Go the asparagus!!
Author:  drmini in aust [ Fri May 08, 2009 2:15 pm ]
I agree.
I use nothing on head and manifold gaskets, and Loctite 515 Master gasket on everything else. It doesn't leak, gasket or no gasket... great stuff.:lol:
Author:  850man [ Fri May 08, 2009 5:28 pm ]
Threebond 1215. I have used them all and this is the best.
Author:  mattsmadmini [ Fri May 08, 2009 5:31 pm ]
where does everyone get these things??? ive trolled the bunnings and auto stores most of the arvo...cant find any cept the peratex? stuff at supercrap.... anyone?
Author:  850man [ Fri May 08, 2009 5:37 pm ]
Bursons.
Author:  weevel [ Fri May 08, 2009 5:40 pm ]
Repco at Camperdown seemed to have a decent range of Loctite when i bought mine - the only reason i remember is that there were so f-ing many of them, i didn't know which was the best one to pick.....so can't say whether they have the one mentioned in the thread...the one i bought came in a green box!! :)
