It is currently Tue Jul 22, 2025 3:31 am
 Post subject: Throwout question
PostPosted: Thu May 14, 2009 10:57 pm
What do the 3W and 7W signify in the numbering of the throwout bearing?
I put a 3w5/8 Timken bearing the my rebuild and have the bearing supplied in the Borg and Beck clutch kit still sealed in this packet It is not labled - no markings and is obviously different looking but just curious thats all.
David L
 Post subject: Re: Throwout question
PostPosted: Thu May 14, 2009 11:15 pm
The Mini King
The 3/W has a larger OD and a flat face The 7/W has smaller OD and is more commonly used as it is a cheaper bearing to buy
PostPosted: Thu May 14, 2009 11:20 pm
Thanks John - thought it might have been more significant than that - Anyone want a cheap clutch release bearing? :roll:
David L
PostPosted: Fri May 15, 2009 8:09 am
If it's a UK made one keep it as a spare. They are not that bad... as I said in the other thread I've had an orange dot plate in mine for years with one of these bearings. :D
PostPosted: Fri May 15, 2009 8:16 am
Thought of that - thing is there are absolutely no markings of any sort on it - OK the kit came from the UK but does that mean the bearing was made there?
David L
PostPosted: Fri May 15, 2009 8:23 am
Nope. Could be from anywhere. The RHP ones had `Made in England' on them.
PostPosted: Fri May 15, 2009 10:01 am
Use the Timkin one
Lillee - 1969 Morris Mini K
PostPosted: Fri May 15, 2009 10:41 am
after putting a timken in mine, its definately quieter
