It is currently Fri Aug 08, 2025 4:19 pm
 Post subject: Want a cheap PCV valve?
PostPosted: Sat May 09, 2009 7:28 am
Probaly need a new diaphram but there cheap enough as well.
UK eBay
David L
PostPosted: Sat May 09, 2009 7:12 pm
You need to check them carefully as there is a metal flap valve inside that can wear out. :wink:
 Post subject: Cheap.
PostPosted: Sat May 09, 2009 8:47 pm
Cheap things give trouble. Buy an expensive one.
"Let us remove your "SHORTS"
