I new there was a couple of small rust bubbles starting to show on the passenger side A panel - well today I bit the bullett and looked into it.
Close Up
And from inside the wheel well
Do I ?
1 - Bog - after treating and filling the space between the two layers with fish oil
2- Cut a piece out and MIG a patch in _ how do I handle the inside panel?
3 - Replace the whole A panel
Advise please.
Might add the magnet test seems to indicate no more bog in the A panel. ( Found some elsewhere but we won't go there
There is a small bubble of rust on the inside higher up on the edge of the seam - 1/2" long by 1/8" wide - picked it off with my fingernail
David L
