It is currently Sat Jul 26, 2025 12:57 am
 Post subject: security question???
PostPosted: Mon May 11, 2009 12:00 am
so just a quick question re: recommendations security solutions for mini's.....
really want something simple, discreet and effective!
was considering just a 'hidden' battery cut-off....??
ideas and experience welcome....
cheers,
miko
PostPosted: Mon May 11, 2009 12:13 am
I have,nt done it yet but the padlock through the handbrake sounds to me like the easiest to get to and hide, the padlock sits under the handbrake boot,you would need a drill press though its all toughened steel.
PostPosted: Mon May 11, 2009 12:32 am
Rover Cooper
or a set of bolt cutters under the back to snap the cable that sits out in the open and easy to get at. :wink: :wink:
PostPosted: Mon May 11, 2009 2:05 am
Dave I dont think you can actually cut a handbrake cable with bolt cutters and if someone wanted to pinch the car,it would go like this, started it, tried to drive it, it wont go anywhere, have a quick look, eventually find the handbrake padlocked, then suddenly there a strange man standing there with an iron bar saying " I wont be gentle when I fark your corpse "
PostPosted: Mon May 11, 2009 5:38 am
haha ,, corpse bit. yeah i like d that idea till i thought about the cutters , i rekon they'd eat through that cable. however the thief probably aint thinking about carring around bolt cutters ,, maybe??
PostPosted: Mon May 11, 2009 8:16 am
hmmm any real suggestions guys??
alarms?
battery cut-off?
etc etc
PostPosted: Mon May 11, 2009 8:18 am
in my first mini I drove to work with the handbrake on. She never did brake the same after that :(
Hidden kill switch is always a good idea.
I read somewhere you can get one where you touch a screw or something in the dash ( a particular one that is) and the other hand on the ignition key and that is the kill switch. If you don't touch said screw now workies.
another question on topic.
Gave my only ignition key to a lock smith so he can cut me some spares. He lost it. Can someone please PM me and let me know how to hot wire a mini. I want to test the wiring I am installing.
D
PostPosted: Mon May 11, 2009 8:19 am
Just remember that people will be reluctant to post what they have on their own car as they will be telling potential thieves what to look for .
The basic's though are hidden or keyed switches for (electric) fuel pump cutoff , a hidden earth switch from the coil to the body and a battery cutoff switch . Just don't tell anyone where you have them or what you've fitted .
PostPosted: Mon May 11, 2009 8:24 am
take the ignition leads with you when you park the car
PostPosted: Mon May 11, 2009 8:25 am
sports850, fair point....
I can see what your saying, and its a fair call.
wasn't after exact details, just a guide as too what works best
according to experience. Even just your post and floss's is
enough to set me in the right direction....
cheers all :)
PostPosted: Mon May 11, 2009 9:36 am
Something I am thinking of was published in an electronics magazine - use a hidden magnetic reed switch (like used in burgular alarms in doors and windows etc) that energises a self latching relay controlling some critical circuit.
You have a magnet in a fob on your key ring that you touch to the surface behind which is the magnetic switch - the circuit completes and the key will then start the car
PostPosted: Mon May 11, 2009 9:42 am
2 things i used to do
1: remove rotor button and put in pocket. worked well especially if i thought i may have had a few to many to drink. can't fit rotor button then shouldn't drive.
2: had an array of switches 4 from memory, that needed to be turned on.
a little excessive but effective.
Boring old battery master in boot, so long as your boot locks, and then it is pretty secure.
- 1962 Beige Delight club car, Rebuilding.
- Motorkana Special
- Minor Mishap, 1958 Morris Minor
-- Last ever Tea Lady at Longbridge--
PostPosted: Mon May 11, 2009 9:45 am
or maybe the rotor button.
or the fuse for the ignition circuit.
PostPosted: Mon May 11, 2009 9:53 am
A similar one I know of was on a classic car that was serviced at a place I used to work at , the owner had a daggy old pair of leather driving gloves with a magnet sewn into them that had to sit on one side of the glovebox (where the magnetic switch was) . When he was leaving the car for a while he'd put the gloves on top of the dash :lol:
You actually can cut handbrake cable with bolt cutters....had to do it on the weekend to remove a handbrake cable set off a trailer....
Sports850 has it all in a nutshell, well except for the wierd security devices like dogs, snakes, hooked up to a couple of 24v batteries or the house mains etc lol
