It is currently Sat Jul 26, 2025 12:58 am
Post new topic Reply to topic  [ 34 posts ]  Go to page 1, 2, 3  Next
 Post subject: stroking!
PostPosted: Sat May 09, 2009 3:46 pm
What options are available for stroking a 998?
Or will it be easier and cheaper to just go to a bigger bore engine? My 998 needs a complete rebuild anyway, so while doing the work, may as well play with it!
Any thoughts?
mooo, I'm a pig!
PostPosted: Sat May 09, 2009 3:48 pm
1100 crank, rods and pistons :lol:
PostPosted: Sat May 09, 2009 3:53 pm
easy enough!....? :D
How big is the standard overbore? I know that everyone has different opinions on this one, just want to see what most go for. The bigger the better? If so, how far can you bore a 998 out? Normal day to day car, not a track car.
mooo, I'm a pig!
PostPosted: Sat May 09, 2009 3:56 pm
The magazine mini experience had an article by Graham Russell on building a good small bore engine. 80 and 100 thou are possible.
Worth trying to get a copy of those magazines (it ran over three issues from memory). PM Watto on here perhaps to see if the article or mags are still available.
PostPosted: Sat May 09, 2009 4:00 pm
thats a lotta bore! :shock:
Available pistons must be few and far between.
mooo, I'm a pig!
no..... crank and pistons, rods are the same same same. :wink:
PostPosted: Sat May 09, 2009 4:02 pm
No No, GR has a wall of them sitting there awaiting an unsuspecting small bore block :lol:
80" is recommended so you have another o/size.
PostPosted: Sat May 09, 2009 4:08 pm
ok, here is the noob in me really coming out. Where is graham russell? I have heard the name dropped a lot here on ausmini, but know nothing about! What is an 80 thou bore worth these days?
mooo, I'm a pig!
PostPosted: Sat May 09, 2009 4:18 pm
Graham did my 1098 - bored out to +100 and supplied and fitted the pistons and assembled the short motor for me and set the cam timing and fitted the oil pump - included replaceing the cam bearings (I supplied the bearings as I already had them) around $1200
David L
PostPosted: Sat May 09, 2009 4:20 pm
If I source the parts, Graham will fit?
mooo, I'm a pig!
PostPosted: Sat May 09, 2009 5:00 pm
PM sent to Watto as I'm interested in this one too.
Dicko
PostPosted: Sat May 09, 2009 5:15 pm
I think this might be the article your looking for, found it a lil while ago, and its a good read.
Linky
I'm grew up on the street, not the hood, the sesame st
PostPosted: Sat May 09, 2009 5:29 pm
Russell Engineering,
113 North Rocks Rd,
North Rocks, NSW
phone (02) 9630 2195.
Cost to bore and hone block $150 approx.
+ pistons...
Graham stocks +.080" and +.100" for both 998 and 1098..
You can go further, IF you can get pistons. +.120" are available for 998s but I've not seen them to suit a 1098.
BTW, the main difference between a 998 and 1098 piston is the pin height to the top (crown). A 1098 one is .148" shorter due to the 0.296" longer stroke.
PostPosted: Sat May 09, 2009 6:05 pm
So,
the pistons and rods are the only difference between 998 & 1098?
PostPosted: Sat May 09, 2009 6:07 pm
Thanks doc! Will give him a call sometime!
Thanks all so far for the good input! Keep it comin!
I read the link provided by roleyfoley. I'll never make an engineer..... it confused the hell out of me! Too many numbers and stuff!! :D
mooo, I'm a pig!
