It is currently Sun Jul 20, 2025 5:12 pm
 Post subject: Putting a 1275 in Beefa
PostPosted: Sat Mar 05, 2005 7:55 pm
Hey guys,
How hard will it be to put a 1275 in beefa? At the moment he has a 1100 in it and I'd like to drop a 1275 in him (damn my fiance for getting me into Minis!).
I just need some ideas on the stuffing around that is involved!
Thanks :D
Lynda
1978 Leyland Mini 998LS All Original *Sally*
2002 Mini Cooper *Coopa*
PostPosted: Sat Mar 05, 2005 8:39 pm
i think you need disc brakes on the front to do it but im not sure
PostPosted: Sat Mar 05, 2005 8:43 pm
Damn I hope not. That costs an arm and a leg to put disc brakes on!
PostPosted: Sat Mar 05, 2005 8:57 pm
its not particularly expensive to convert to discs if you dont mind going to bigger wheels. the bigger wheel will then be the major expense... but for the money you spend on a 1275 you can ring some major power gains out of your 1100.. will try and find a few links others have given me on the subject
PostPosted: Sat Mar 05, 2005 8:59 pm
Apart from that and getting a 1275 donk (with primary gear) it's pretty easy!
It'll fit OK on all 4 synchro boxes.
On 3 synchro boxes with a bit of checking.
On early 850 boxes with major surgery (I did that once). :P
PostPosted: Sat Mar 05, 2005 9:01 pm
Cool, I just want him to go a little better, not harder.
Thanks for your help!
PostPosted: Sat Mar 05, 2005 9:02 pm
it would be really easy if you could get cooper s front cuts 8)
PostPosted: Sat Mar 05, 2005 9:05 pm
HMMM, sounds like a head ache if I have to put disc brakes on him.
What can I do to squeeze more power from the 1100?
PostPosted: Sat Mar 05, 2005 9:07 pm
Camshaft
Head work
Bigger carb(s) :wink:
Bore it to 1152 or 1220cc :P
PostPosted: Sat Mar 05, 2005 9:14 pm
I dunno if I like the idea of boring him out though, that cant be good for him... :?
PostPosted: Sat Mar 05, 2005 9:21 pm
1152 is good, and pistons are available.
1220 is pushing it, and pistons (Hillman Imp) are like rocking horse dung here now.
8)
PostPosted: Sat Mar 05, 2005 9:25 pm
You want more power and you don't want to upgrade the brakes. That can't be good for him.... :lol:
PostPosted: Sat Mar 05, 2005 9:26 pm
Ok so if I bore him out to 1152 will it make the walls of the bore weaker?
I just want to get as much infor as I can before I do it
PostPosted: Sat Mar 05, 2005 9:29 pm
LOL u have a point there Morris, but hey a woman driving him cant be good for my baby either!
PostPosted: Sat Mar 05, 2005 9:32 pm
No problem- 1152 is a standard factory piston oversize (+.060"). Safe to bore that far, definitely.
Users browsing this forum: Bing [Bot] and 65 guests
