mini_mad_matt wrote:
To crank it on the floor just get your battery, some jumper leads and hook the earth onto the motor, and just touch the positive to where the power cable goes onto the back of the starter. No need for a solenoid
...and to run it, just wire from the + jumper lead to the coil + terminal. To stop it, pull the earth jumper off the motor.
I hang a 5L jerrycan on the wall and gravity feed the fuel to the carby..
If the alternator is on the motor, you won't hurt it by spinning it, AS LONG AS no wires are connected to it at all.
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
