Whats this off?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=53121
Author:  ashep22 [ Mon May 11, 2009 9:05 pm ]
Post subject:  Whats this off?
Was looking over the engine today and seen these, they look they they should be connected to something but i wouldnt have a clue what.. any help would be great.
Thanks, Ash
Author:  Mick [ Mon May 11, 2009 9:10 pm ]
http://img8.imageshack.us/my.php?image=dsc00933jjx.jpg
Well one of the links shows a noise suppression capacitor. It suppresses electrical ignition noise from ruining your radio interference. Not always required, but easy to put back on, just put it under the nearest coil mounting bolt and forget about it.
The other link doesn't work...
Author:  Timbo [ Mon May 11, 2009 9:11 pm ]
Its a supressor, its supposed to stop ignition noise interfering with your radio. It should be bolted to something thats earthed, or you can throw it away.
Author:  ashep22 [ Mon May 11, 2009 9:16 pm ]
Edit: fixed the pictures
Author:  Mick [ Mon May 11, 2009 9:19 pm ]
Oh lucky you, two suppression caps...twice the audio suppression power... ;)
Chuck one or both out.
Author:  ashep22 [ Mon May 11, 2009 9:29 pm ]
just another quick thing, is the leads for the dizzy set up right, im pretty sure they are, just need confirmation.
Author:  EST-071 [ Mon May 11, 2009 9:32 pm ]
Yep all good.
Cheers Pete
Author:  ashep22 [ Mon May 11, 2009 9:38 pm ]
Great :D thanks for the help guys..
Author:  mattsmadmini [ Mon May 11, 2009 11:44 pm ]
so thats what they are.... :lol:
Author:  Wombat [ Tue May 12, 2009 8:50 am ]
Wondering if with 2 suppressors the PO was having noise problems that were hard to get rid of - maybe needs new brushes in the alternator and clean up the commutator
Author:  drmini in aust [ Tue May 12, 2009 9:54 am ]
Alternators don't have commutators, they just have 2 slip rings so no commutation noise there...
But if you must, you put it on the output stud, never the field connection.
Author:  Wombat [ Tue May 12, 2009 10:06 am ]
Thats what I meant - still might need a clean
Author:  Mick [ Tue May 12, 2009 2:49 pm ]
2 caps in series across the same supply add up like resistors in series. This changes the tuned filtering of both of the caps to twice the frequency.
If you had a problem with noise, it probably will be improved by removing one.
