fuel pump to carby
https://www.ausmini.com/forums/viewtopic.php?f=2&t=53124
Author:  ashep22 [ Mon May 11, 2009 10:42 pm ]
Post subject:  fuel pump to carby
should these two points be connected? i just noticed it..
Thanks.
also, im going to try and start it for the first time, i have never driven let alone started one a mini before, so any advice/tips with the choke, accelerator... its a clubman 1100, the person i bought it off had it running about 6 months ago, but couldnt get it started for me when i bought it as it had dirty fuel, dead battery..
Any advice would be great..
Thanks, Ash.
Author:  Wombat [ Mon May 11, 2009 11:08 pm ]
Fuel won't get to the carby if they're not. Short length of fuel hose with a clip each end will do the trick
Author:  mattsmadmini [ Mon May 11, 2009 11:41 pm ]
small bit of fuel hose between it... a fuel filter later on to keep it all together, just check the tank is connected first...
Author:  DTrain [ Tue May 12, 2009 11:59 am ]
since its been sitting, make sure you crank it over (with the lead from the coil off) till you get oil pressure. check the oil, water and fuel floats that everything is as its supposed to be. then crank her over
