It is currently Tue Jul 22, 2025 9:36 pm
 Post subject: Bosch SU12 Coil
PostPosted: Fri May 15, 2009 2:16 pm
Thought mine was a GT40R until I dug it out and it turns out to be a standard SU12. Looked back at the discussion about resistors etc and don't know if a need a 'resistor' one or not. It is connected to a standard 25D distributor still running points and converted from dynamo to alternator for power (negative earth)
Dave K.
PostPosted: Fri May 15, 2009 2:45 pm
SU12 is the Bosch replacement for std Mini. It is a 12V coil (3 ohm), not a `use with ballast resistor' one.
PostPosted: Fri May 15, 2009 2:57 pm
Thanks Doc - so what does (if needed) the resistor do? Is it for electronic ignition, type of wiring harness?
Dave K.
PostPosted: Fri May 15, 2009 3:06 pm
The idea of using a resistor coil is to get more V for cold starting, nothing more.
Instead of having a 12V coil with 3 ohm primary resistance you have 1.5 ohm one , and a 1.5 ohm wire wound (onto ceramic) resistor wired in series with it.
In normal running, 12V is applied to the end of the resistor so the primary is 1.5 + 1.5 =3 ohms.
When COLD cranking (at maybe 7 or 8V) there is another connection made from the starter switch to the coil + terminal, bypassing the resistor. 7V into 1.5 ohms. So you get more output voltage during cranking than you would with the same 7V into 3 ohms.
That is how my Valiant and other cars worked it. As for later UK Minis, I'm not sure.
Users browsing this forum: Barkfast, Bing [Bot] and 92 guests
