Flywheel Help
https://www.ausmini.com/forums/viewtopic.php?f=2&t=53180
Author:  Chooka [ Wed May 13, 2009 10:47 am ]
Post subject:  Flywheel Help
Hi guys I've seached and couldn't find an answer to my problem, here it is...
I'm trying to undo the 6 nuts on the flywheel, I got 2 of them off with no dramas, but when I try to undo the other 4 the nut and the whole bolt turn. I'm totally stuck as to how to get them off, any ideas?
Edit: Do I need to undo these to get the flywheel off?
Author:  Tombo [ Wed May 13, 2009 11:36 am ]
You don't need to undo them 6.
You need a flywheel puller to remove the entire assembly as one.
Author:  Chooka [ Wed May 13, 2009 11:39 am ]
Thanks for that...now off to find a puller.
Author:  mini-dunger [ Wed May 13, 2009 12:18 pm ]
best bet is to make one out of a thick plate. drmini has a how too on here somewhere.
Author:  drmini in aust [ Wed May 13, 2009 1:15 pm ]
http://www.ausmini.com/forums/viewtopic.php?t=12888
