speedo question https://www.ausmini.com/forums/viewtopic.php?f=2&t=53194 |
Author: | david rosenthal [ Wed May 13, 2009 3:50 pm ] |
Post subject: | speedo question |
Just finished the last box of bits and found this speedo in it. It has two odometers in the face and two seperate drives on the back.I have included a pic of the std[I think] type for early 850 showing the difference. Open to any suggestions or ideas ![]() ![]() ![]() ![]() |
Author: | Wombat [ Wed May 13, 2009 4:02 pm ] |
Trip meter? any way of resetting it to zero? |
Author: | drmini in aust [ Wed May 13, 2009 4:02 pm ] |
In the UK they did make tripmeter speedos. Is that another drive on the back (pic is out of focus) or is it a reset knob/drive square? It would have had a 180° bit of speedo cable to a knob next to the speedo. My Fiat had this setup too. |
Author: | david rosenthal [ Wed May 13, 2009 4:33 pm ] |
It has a separate drive [top LH corner on back] but is a smaller thread. it resets by pushing the drive in. That is only thing I can see on it to re-set. Seems a bit stupid way of doing it.It's a bit gummed up but the numbers try to move, or maybe they wanted you to see the milage in stero ![]() I am wondering what model car it came from. |
Author: | sports850 [ Wed May 13, 2009 4:36 pm ] |
Any model numbers on it David or revolutions per whatever markings (can't remember the wording now but the code that tells you what it works with ) ? |
Author: | TheMiniMan [ Wed May 13, 2009 4:41 pm ] |
yeah it`s a seperate trip metre & should have a short cable attached to it with a small Knurled knob on the end of it. i have a couple of these speedos They`re cool hey? ![]() |
Author: | david rosenthal [ Wed May 13, 2009 4:56 pm ] |
The top one is miles and tenths. It only goes to 999.9 the bottom one is also miles and tenths going by the colours of the numbers. They are a bit faded. Max speed 90mph[very optimistic] The only serial No. I can't completely read, but it's 51 118 605 01*** It was in this center housing. a paper or carboard one not plastic. Thanks Doc about the tip off with the drive, Now I know what that liitle bit was that I threw into the trailer with the other rubbish ![]() ![]() ![]() |
Author: | david rosenthal [ Wed May 13, 2009 5:03 pm ] |
Hey Matt ,got any idea what these were fitted into. and can you PLEEEEEEEEEEEEASE post a pic of the bit you are talking about. I want to make sure it is the right bit before I go thru all the junk it the trailer ![]() ![]() I have had enough of yes i will no i wont keep it |
Author: | Morris 1100 [ Wed May 13, 2009 5:46 pm ] |
It looks like an 850 speedo but isn't! I bet someone has had a play with it. Lots of MGs, Morris and big Austins had the trip meter, they had a cable that run from the back of the speedo to the bottom of the dash. This one on Ebay is from a Morris Cowley, it shows the re-set cable.. |
Author: | TheMiniMan [ Wed May 13, 2009 8:49 pm ] |
Ha!!!! Saved me taking a pic & hosting & posting it looks just like that one that morris 1100 posted ![]() too easy ![]() |
Author: | John Smidt [ Wed May 13, 2009 10:17 pm ] |
david rosenthal wrote: It was in this center housing. a paper or carboard one not plastic.
![]() This is from the very early Mini 1960 1961 would be a sought after item |
Author: | david rosenthal [ Wed May 13, 2009 10:43 pm ] |
John Smidt wrote: david rosenthal wrote: It was in this center housing. a paper or carboard one not plastic. ![]() This is from the very early Mini 1960 1961 would be a sought after item I was a happy s a pig in sh*t when I found the housing. The rats had eaten half of the one that was in my car. All I need now is some seats, the bloody things ate them as well. at least the cat ate the rats ![]() |
