Brake pipe question..how long where it goes etc https://www.ausmini.com/forums/viewtopic.php?f=2&t=53214 |
Author: | minifreak1 [ Thu May 14, 2009 6:27 am ] |
Post subject: | Brake pipe question..how long where it goes etc |
as the topic sates. i fitted the new pipe i had made yesturday...started from the engine bay..went between the subframe and body of car...and followed the same path the original went i think...im sure the main pipe from front to rear goes the same rute as the hydro pipe on the drivers side??? im not running hydro anymore so i had room to fix it to the floor... but when i got to the rear the pipe is about 10 inch to long??? now im thinking ive not followed the parth i was ment to . dose anyone have a photo of where they put there main line and the path they took?? i gse ill just have to cut and re do the end so its not as long. i had the whole brake pipe kit made buy a mini mob here in melbourne and all other pipes fitted great no hassle. advice welcome. |
Author: | Wombat [ Thu May 14, 2009 7:01 am ] |
There is a 'pig tail' on the end where it goes into the pressure regulator on the read sub frame - about 2½"-3" in diameter - that would take up 10" |
Author: | minifreak1 [ Thu May 14, 2009 2:49 pm ] |
anyone got a photo of this so called pig tail??? to me it looks crap the way it is but if its ment to be that way ill leave it. |
Author: | Mick [ Thu May 14, 2009 5:15 pm ] |
I didn't bother to do one ![]() |
Author: | Wombat [ Thu May 14, 2009 5:22 pm ] |
I'll take a pic when I get home - It's purpose is to provide strain relief between the body and the subframe that moves on it's rubber mounts |
Author: | Wombat [ Thu May 14, 2009 7:54 pm ] |
Original: ![]() My copy: ![]() |
Author: | minifreak1 [ Fri May 15, 2009 6:21 am ] |
thanks for the photos. ill make my piggy tail later this arvo. |
Author: | winabbey [ Fri May 15, 2009 7:48 am ] |
Resting it in lots of muck and rotten fruit for a while will make the piggy a little easier to work with ... |
Author: | minifreak1 [ Fri May 15, 2009 5:52 pm ] |
the only thing i cant do is put the pipe between the subframe and the car body... cant see this being to much of a hassle ??? |
