It is currently Sun Jul 27, 2025 2:45 am
PostPosted: Fri May 15, 2009 2:07 pm
fitted everything back together as i should be radiator wise and came to fitting the top bracket, now firstly i hope i have it up the right way so i have it facing so the kink in facing downwards if you get me?! the hook part going under the forward facing thermo outlet!?
This right???
If so... Why the F$£k does the fan foul the cowling!?
Help appreciated!
PostPosted: Fri May 15, 2009 2:49 pm
This (no not mine) is typical for a top rad mount-
PostPosted: Fri May 15, 2009 3:29 pm
This right???
Help appreciated!
What size engine is it? What type of fan....plastic or metal?
Im guessing that the radiator is verticle (same space at the top of the rad to the bottom against the radiator cowling on the inner guard), not on an angle in or out at the top?
Where in the shroud does the fan sit......it may need a spacer or spacing, or your shroud may need a small amount of adjusting in a certain spot.
PostPosted: Fri May 15, 2009 3:53 pm
is it a clubman bottom bracket with a roundnose top (i think thats why theyre different could be wrong) but mine did that but in reverse.. it was fowling on the other side.. used a smaller braket and it worked. if all else fails make your own theyre pretty simple
Potato
PostPosted: Fri May 15, 2009 4:57 pm
Definately fitted it wrong.... now it's the right way up!
All is good, here is a snap of my new fan in it's overhauled home!
PostPosted: Fri May 15, 2009 4:58 pm
Fan is on back to front. :wink:
Very pretty but.
PostPosted: Fri May 15, 2009 5:09 pm
please say ur kidding!!!!!!! i replaced in same way old 1 came off!!!!! lol
PostPosted: Fri May 15, 2009 5:10 pm
just checked!!! hahahahahaha 8)
PostPosted: Fri May 15, 2009 5:41 pm
Now you get a second shot at remembering which way the radiator top bracket goes on ;)
PostPosted: Fri May 15, 2009 6:10 pm
Don't Ya Hate that :twisted:
PostPosted: Fri May 15, 2009 6:49 pm
hahaha.
i hate it when you do that!!! :shock:
