ball joint grease https://www.ausmini.com/forums/viewtopic.php?f=2&t=53259 |
Author: | Leighton [ Fri May 15, 2009 5:46 pm ] |
Post subject: | ball joint grease |
just starting to fit the new ball joints what type and grade grease do you guys recommend for new ball joints? thanks leighton |
Author: | TheMiniMan [ Fri May 15, 2009 5:49 pm ] |
I use moly |
Author: | gafmo [ Fri May 15, 2009 6:05 pm ] |
TheMiniMan wrote: I use moly
Does your wife know ![]() |
Author: | TheMiniMan [ Fri May 15, 2009 6:24 pm ] |
Shhh,,, don`t tell anyone but Molly is a really nice girl & i don`t want her to get it trouble ![]() |
Author: | Morris 1100 [ Fri May 15, 2009 6:43 pm ] |
TheMiniMan wrote: Shhh,,, don`t tell anyone but Molly is a really nice girl & i don`t want her to get it trouble
![]() Any girl that greases your ball-joints is a keeper. ![]() |
Author: | TheMiniMan [ Fri May 15, 2009 6:58 pm ] |
she stepped in some mud the other day, so i video-ed it & got some "Dirty-Footage" ![]() |
Author: | drmini in aust [ Fri May 15, 2009 7:23 pm ] |
I use whatever EP2 lithium grease is cheapest in cartridge form. I've found buying them from a BP servo is cheaper now than Supercrap. |
Author: | Drexxle [ Fri May 15, 2009 7:28 pm ] |
what do you use in wheel bearings. I used moly in the ball joints, but i used caltex HTB in the bearings. |
Author: | drmini in aust [ Fri May 15, 2009 7:51 pm ] |
Castrol HTB in the bearings, LMM in CVs. Steering racks I use Castrol LSX90. It's an LSD diff oil, has additives for metal to metal sliding contact- good for where the rack slides on the steel pressure pad. |
Author: | Morris 1100 [ Fri May 15, 2009 8:07 pm ] |
drmini in aust wrote: Steering racks I use Castrol LSX90. It's an LSD diff oil, has additives for metal to metal sliding contact- good for where the rack slides on the steel pressure pad.
That's good, I still have a bottle of LSX90 left over from the HQ race car (but don't HQs run open diffs? ![]() ![]() |
Author: | simon k [ Fri May 15, 2009 8:41 pm ] |
Morris 1100 wrote: drmini in aust wrote: Steering racks I use Castrol LSX90. It's an LSD diff oil, has additives for metal to metal sliding contact- good for where the rack slides on the steel pressure pad. That's good, I still have a bottle of LSX90 left over from the HQ race car (but don't HQs run open diffs? ![]() ![]() I thought they used no oil at all in the diff so it welds itself up after a couple of corners... |
