Internal door hinge https://www.ausmini.com/forums/viewtopic.php?f=2&t=53303 |
Author: | micowen [ Sun May 17, 2009 10:51 am ] |
depends on what look you are going for. You could always try "lamborghini hinges". Dont know much about them except that they are a universal fit, and it makes your doors open up, not out. |
Author: | Asphalt [ Sun May 17, 2009 11:05 am ] |
Did australian Minis never have them? ![]() ![]() ![]() [click] Or am I missunderstanding something? ![]() Cheers, Jan |
Author: | Tadhg [ Sun May 17, 2009 11:24 am ] |
Jan's got it - British built Minis got internal door hinges on Mk III, whereas Australian Minis - despite the change to 'burstproof' door latches - retained external door hinges. ![]() The easiest way to get internal door hinges in a Mini is to buy a Rover. ![]() ![]() If you want to convert your existing Mini, all the best... I have no idea how you'd go about that, unless you decided to cut panels and weld in the Rover system... ![]() |
Author: | Harley [ Sun May 17, 2009 12:25 pm ] |
The door profile and A panel are different in section. An internal hinge conversion wouldn't be easy. |
Author: | drmini in aust [ Sun May 17, 2009 12:46 pm ] |
Out here, internal hinges and square cornered doors look so WRONG!! ![]() |
Author: | mattsmadmini [ Sun May 17, 2009 4:26 pm ] |
why would you want internal Ash? Unless you were wanting to give the clubby a shaved and smooth look.... Changing the external ones to internal requires a bit of work and a lot of patience... if its the gaskets your worried about you can get them from any mini supplier... or give me a bell and ill make you some rubber ones.... ![]() |
Author: | Kennomini [ Sun May 17, 2009 7:17 pm ] |
Ok, it is possible as I had it done to my panelvan but it's rather tricky and expensive. ![]() Basically I supplied the panel beater with a Rover front cut and a pair of rover doors. He then cut the body section of the A pillar out and welded in the same section from the Rover mini. ![]() Then he cut the front couple of inches off each door and replaced them with the same section of Rover door. ![]() This gave me Mk III door hinges ans hinge panel with Ozy burst proof handles and Ozy Mk II windows so I still have the quarter lights. |
Author: | Harley [ Sun May 17, 2009 7:42 pm ] |
Wow! ![]() Certainly not a conversion for a painted car! I'm surprised you didn't go the whole hog and modify the doors for single piece glass. |
Author: | Kennomini [ Sun May 17, 2009 9:50 pm ] |
Thought abut it but we weren't sure if it would work as the hoops are slightly different and we didn't have the B pillar to fit the complete Rover doors ![]() ![]() |
