How much oil
https://www.ausmini.com/forums/viewtopic.php?f=2&t=53323
Page 1 of 2
Author:  phillz [ Sun May 17, 2009 8:47 pm ]
Post subject:  How much oil
How much oil does it take to fill a motor to it's correct level when you do a change including filter. I seem to be using nearly 5.8 litres or there abouts to get it to the top level on the dipstick. :?
Author:  1071 [ Sun May 17, 2009 8:56 pm ]
Seems a bit to much to me. I have about half a pint left out of 5 litres when I did mine yesterday. Depends a bit on how much you pour into the filter.
Cheers, Ian
Author:  sgc [ Sun May 17, 2009 8:58 pm ]
I normally fill the filter to the point where I can screw it on without spilling, and use pretty close to 5L exactly, leaving 1L of KMX for top-ups ;)
Author:  Morris 1100 [ Sun May 17, 2009 8:59 pm ]
Always less than 5 litres, even with the big cartridge filter.
Author:  phillz [ Sun May 17, 2009 9:00 pm ]
Going by the book it's to much but do I go by the book or the dipstick ?
Author:  henry the mini [ Sun May 17, 2009 9:01 pm ]
By memory the haynes book says 4.8 litre plus filter!
But correct me if i am wrong
Louis
Author:  sgc [ Sun May 17, 2009 9:03 pm ]
Louis
Close, 4.83 litres including filter ;)
Author:  Morris 1100 [ Sun May 17, 2009 9:04 pm ]
Louis
Depends on the filter. :wink: The spin-on is smaller than the cartridge. There is a bit of variation in the spin-ons as well.
Author:  Tombo [ Sun May 17, 2009 9:04 pm ]
Stupid question, but is your car sitting flat?
I put in a straight 5L, it allows for the first month of leaks :oops:
Author:  Morris 1100 [ Sun May 17, 2009 9:06 pm ]
I would be looking carefully at your dipstick. There is something wrong. Maybe the stick or the tube is the wrong one.
Author:  henry the mini [ Sun May 17, 2009 9:07 pm ]
Might be a stupid comment but i have done that.
Allow a bit of time for the oil to go down the sump :?, don't check strait away.
Louis
Author:  phillz [ Sun May 17, 2009 9:08 pm ]
Might measure it next time and go by the book. And yes it's on flat ground.
Author:  sports850 [ Sun May 17, 2009 9:11 pm ]
Just checking , this is a manual box isn't it ?
Author:  phillz [ Sun May 17, 2009 9:15 pm ]
Yes manual MK1 cooper motor.
Author:  Austin850 [ Sun May 17, 2009 9:33 pm ]
Are you sure that you've got a 6 litre container of oil? Maybe you've only got a 5 litre this time. Just an idea.
