overheating problems... https://www.ausmini.com/forums/viewtopic.php?f=2&t=5338 |
Page 1 of 2 |
Author: | djstib [ Sun Mar 06, 2005 9:24 pm ] |
Post subject: | overheating problems... |
okay i got problems now. My mini likes to overheat... first it was every now and then now its happening all the time? So i have thought about it and talked to some people and they told me it could be the waterpump but its not makin funny noises... so the other thing it could be is the thermostat... is this right? anyone help me out? cuz its goin all the way up to 110 degrees now.. use to only go up to 70degrees? |
Author: | min13k [ Sun Mar 06, 2005 9:29 pm ] |
maybe the thermo stat is stuffed??? makka |
Author: | sg [ Sun Mar 06, 2005 9:38 pm ] |
Do the old trick.......... get a radiator thermometer (if you know a mechanic he should have one), and, when the mini reaches operating temp, ease off the radiator cap (whilst protecting yourself with a big towel) ,let the pressure stabilize and pop the thermometer in and see what temp comes up....... I thought i had massive temp probs with Slidey and when the temp was checked i found out that my gauge was out about 30 degrees ![]() |
Author: | gafmo [ Sun Mar 06, 2005 10:06 pm ] |
Could be the temp thermostat...(my Guess) Temp Sender or a blockage in the rad...Don't talk to me about Rad's today ![]() What was the last time you cleaned out the rad/system.....what colour is the water...have you instaled a heater ![]() |
Author: | Stuartminidlx [ Mon Mar 07, 2005 6:01 pm ] |
yes i would put a thermometre in the rad but u can start with the cap off so u don't risk getting burnt |
Author: | mini_van_1970 [ Mon Mar 07, 2005 6:12 pm ] |
Check your timing and mixture first. If the mixture is lean it will overheat same goes if your timing is out. Dad told me that one. Pat |
Author: | gafmo [ Mon Mar 07, 2005 7:20 pm ] |
Well don't you hate that... I had that call this aftrenoon... ![]() Changed Oil Filter / Oil and tappet Gasket... Why you ask did I not touch the Themo...Changed it two week's again with a good flushing of the system Sue needs it for daily drive lets hope thats all it is |
Author: | drmini in aust [ Mon Mar 07, 2005 7:24 pm ] |
gafmo wrote: Well don't you hate that...
I had that call this aftrenoon... ![]() Changed Oil Filter / Oil and tappet Gasket... Why you ask did I not touch the Themo...Changed it two week's again with a good flushing of the system Sue needs it for daily drive lets hope thats all it is Check the timing Gaf, if retarded it will run hotter. ![]() |
Author: | gafmo [ Mon Mar 07, 2005 7:26 pm ] |
Hasent been touched and as it was at the Dyno...We have just changed to Needle to BCA to BDP...and it was running all okay on the weekend |
Author: | drmini in aust [ Mon Mar 07, 2005 7:43 pm ] |
Mini Mad's was way retarded when we checked after dyno day, he had ~same power there as you. |
Author: | 68matic [ Mon Mar 07, 2005 7:54 pm ] |
he was so cut when he found out too eh that little bit more extra hp |
Author: | gafmo [ Tue Mar 08, 2005 5:23 pm ] |
I'll give a slight clockswise turn to noght Cheers we'll see hoe that goes ![]() |
Author: | Mini Mad [ Tue Mar 08, 2005 6:34 pm ] |
68matic wrote: he was so cut when he found out too eh
that little bit more extra hp ![]() ![]() Gaf...you want to turn it toooo the left...the left i tell ya ![]() |
Author: | drmini in aust [ Tue Mar 08, 2005 6:37 pm ] |
Ooooh Josh, but you are aweful... ![]() |
Author: | Mini Mad [ Tue Mar 08, 2005 6:45 pm ] |
who me?! ![]() |
