moke question https://www.ausmini.com/forums/viewtopic.php?f=2&t=53423 |
Page 1 of 2 |
Author: | david rosenthal [ Wed May 20, 2009 3:03 pm ] |
Post subject: | moke question |
did the 67 mokes have spacer drums or the std type and does anyone have any seats or frames or pics so that I can fit/make some |
Author: | mattsmadmini [ Wed May 20, 2009 3:07 pm ] |
std drums mate, pics of seat frames are you after? |
Author: | mattsmadmini [ Wed May 20, 2009 3:10 pm ] |
http://cgi.ebay.com.au/MINI-MOKE-SEAT-FRAME_W0QQitemZ140320728045QQcmdZViewItemQQptZAU_Car_Parts_Accessories?hash=item140320728045&_trksid=p3286.c0.m14&_trkparms=66%3A2%7C65%3A1%7C39%3A1%7C240%3A1318%7C301%3A1%7C293%3A1%7C294%3A50 thats them. it should have a slight bend backwards at the top to suit the original viynl covers, but if your gonna make some yourself... EDIT ![]() you can see at the bottom of the picture what i mean... |
Author: | david rosenthal [ Wed May 20, 2009 3:25 pm ] |
Thanks Matt for that. I am trying to sort out what has been changed on this thing so that I can made it original. I found a original sales brochure on the moke with the parts I picked up and have been trying to work out whats different from that. It still has original bars front and back with the magic wand gearbox. The rear arms were changed for 13" ones. The brake drums on it are spacer, but I have plenty of std ones. The other question was the steering wheel mini type or the two spoke one with BMC in the center |
Author: | drmini in aust [ Wed May 20, 2009 3:31 pm ] |
On a 67 Moke it would be the early Mini 2 spoke `bus wheel'. |
Author: | TheMiniMan [ Wed May 20, 2009 3:51 pm ] |
I think the 67 mokes had 1/2 inch wide drums didn`t they? The very early mokes had std flat drums, then they changed over to 1/2inch wide & the late ones had 1inch wide |
Author: | david rosenthal [ Wed May 20, 2009 8:05 pm ] |
TheMiniMan wrote: I think the 67 mokes had 1/2 inch wide drums didn`t they?
The very early mokes had std flat drums, then they changed over to 1/2inch wide & the late ones had 1inch wide Well!!!!!! that's interesting. I just checked and the ones on it are 1/2" spacer. I checked some other spacer drums I have and they are 1" So maybe these are the correct ones for this car. The thing that threw me was the 13" arms that had been put on the back but the rear has same drums. Pulled one off and brand new. Never fired a shot ,so I hope the rest are the same ![]() ![]() Thanks for that Matt I was about to pull the lot off and put them in the spare parts dept. |
Author: | drmini in aust [ Wed May 20, 2009 8:08 pm ] |
I thought all the little wheelers had flat drums, and they went to spacer drums with the 13" wheels? But a 67 is/was a little wheeler. |
Author: | mattsmadmini [ Wed May 20, 2009 8:26 pm ] |
drmini in aust wrote: I thought all the little wheelers had flat drums, and they went to spacer drums with the 13" wheels?
But a 67 is/was a little wheeler. thats what i thought.... ![]() |
Author: | TheMiniMan [ Wed May 20, 2009 10:07 pm ] |
ha ha,,, i still have some trivial answers up my old sleeves yet hey? ![]() |
Author: | david rosenthal [ Wed May 20, 2009 10:52 pm ] |
OK Matt now do the 1/2"spacer drums go with the 850 magic wand gear shift as well for this model. I have triple checked the original moke sales brochure and looking at the pics of the wheels I would be both my nuts that it has spacer drums. The position of the rims in relation to the cv nut . The pics show a magic wand gear shift. Now next question is the "uni drives" rubber type or cooper S type uni. |
Author: | TheMiniMan [ Thu May 21, 2009 7:49 am ] |
coul;d be rubber ,,, but more likely to be "S" unis I don`t know that change point sorry |
Author: | bnicho [ Thu May 21, 2009 9:07 am ] |
You are probably better off asking these questions on the Moke forum. It should have a pudding stirrer, but I'm not sure about the drums question. I know early 13" wheel Mokes had the 1/2 spacer, but I'm not sure if anty little wheelers did. EDIT: Oops, I meant Magic Wand. I get the two mixed up. |
Author: | drmini in aust [ Thu May 21, 2009 9:24 am ] |
A `67 should have 3 synchro box and magic wand. The `puddin' stirrer' came later (1969?) with the adapted 4 synchro remote box. |
Author: | graham in aus [ Thu May 21, 2009 9:36 am ] |
I've got an unmolested (but rusty) 67 in the shed at home (numbered in the first 2000) , I'm fairly sure it has flat drums, rubber unis and the two spoke wheel, I'll confirm all later! ![]() As Bnicho said, there are people on the Moke forum who've had lil wheelers from new! ![]() |
