It is currently Wed Jul 30, 2025 10:39 pm
 Post subject: Block removal
PostPosted: Thu May 21, 2009 8:40 pm
Hey, a quick question. To remove the block from the gearbox, ive undone the dozen bolts around where the block joins the gearbox, removed the flywheel etc. but i was wondering do i need to remove all the bolts from inside where the clutch was? and do i need to remove the cover at the other end and remove the cam? Also to pull the block off do i just pull it upwards or is there a "fancy" way of doing it?
Sorry if these questions are stupid but i just want to make sure im doing it right
Thanks Blake
PostPosted: Thu May 21, 2009 8:45 pm
This space for rent
Did you remove the alloy clutch housing and drop gears? The engine won't separate from the box until you do.
PostPosted: Thu May 21, 2009 8:47 pm
You will need to remove the entire alloy clutch/flywheel housing if you haven't already (I'm assuming that's still on from your "all the bolts from inside where the clutch was" question) , also check at the very front of the motor (timing chain end) to see if you haven't missed any bolts hidden in there . We've all missed a bolt at some time or another and have cursed trying to split the motor and the box .
PostPosted: Thu May 21, 2009 8:53 pm
oh ok kool i wasnt sure if the clutch housing bit came off or not. but yeh thanks i'll give it a go tomorrow
I'm Betting thier are two Bolts
One Clutch Cover and the pespy one Block to Gear box up the back drivers side :roll:
PostPosted: Thu May 21, 2009 9:44 pm
don't miss the 2 short bolts in behind the timing cover....
PostPosted: Thu May 21, 2009 10:03 pm
yep i forgot those ones!!!!! thanks
Users browsing this forum: lomin and 74 guests
