Block removal https://www.ausmini.com/forums/viewtopic.php?f=2&t=53466 |
Author: | blake12345 [ Thu May 21, 2009 8:40 pm ] |
Post subject: | Block removal |
Hey, a quick question. To remove the block from the gearbox, ive undone the dozen bolts around where the block joins the gearbox, removed the flywheel etc. but i was wondering do i need to remove all the bolts from inside where the clutch was? and do i need to remove the cover at the other end and remove the cam? Also to pull the block off do i just pull it upwards or is there a "fancy" way of doing it? Sorry if these questions are stupid but i just want to make sure im doing it right Thanks Blake |
Author: | sgc [ Thu May 21, 2009 8:45 pm ] |
Did you remove the alloy clutch housing and drop gears? The engine won't separate from the box until you do. |
Author: | sports850 [ Thu May 21, 2009 8:47 pm ] |
You will need to remove the entire alloy clutch/flywheel housing if you haven't already (I'm assuming that's still on from your "all the bolts from inside where the clutch was" question) , also check at the very front of the motor (timing chain end) to see if you haven't missed any bolts hidden in there . We've all missed a bolt at some time or another and have cursed trying to split the motor and the box . |
Author: | blake12345 [ Thu May 21, 2009 8:53 pm ] |
oh ok kool i wasnt sure if the clutch housing bit came off or not. but yeh thanks i'll give it a go tomorrow |
Author: | gafmo [ Thu May 21, 2009 8:53 pm ] |
I'm Betting thier are two Bolts One Clutch Cover and the pespy one Block to Gear box up the back drivers side ![]() |
Author: | drmini in aust [ Thu May 21, 2009 9:44 pm ] |
don't miss the 2 short bolts in behind the timing cover.... |
Author: | blake12345 [ Thu May 21, 2009 10:03 pm ] |
yep i forgot those ones!!!!! thanks |
